Issues following BlueCruise update - Lane Centering not working
m_bt54
Bryan
Massachusetts
IT Director
What did you roll it back to? & how can you roll back a update ?
Last version that is also BC 1.4 compatible. Check your messages
aemploye
Sam
Phoenix AZ
Update - he was able to fix my issue. Have the circle back no warning or issues!
Thanks!
Should there be some caution with any further update seems like i can't uodate anymore in fear of running into this issue again.
m_bt54
Bryan
Massachusetts
IT Director
Thanks!
I might be updating mine again to see if the same thing happens. Most likely over the next couple days. I’ll let you know how it goes.
m_bt54
Bryan
Massachusetts
IT Director
Thanks!
I would avoid updating at least till another IPMA is released. I updated again today and am having the same issue.
m_bt54
Bryan
Massachusetts
IT Director
At least we know now it is something with the update itself and not missing files/ corruption during install. Slightly more info than we had on the situation this morning.
m_bt54
Bryan
Massachusetts
IT Director
I figured it wouldn't be a quick fix for us
If you have a minute, I’d like to try to figure out any similarities between our trucks that might help explain why we seem to be the only one so far who have had this issue in needed to roll back to resolve it.
I believe I remember seeing that this was your first time updating your truck and that you havent made any Forscan changes. Is that right?
Have you made any other changes/ modifications such as bigger tires, level, lift? Have you calibrated your cameras with FDRS.
would be interested to hear anything out that stands out that I didn’t mention too.
aemploye
Sam
Phoenix AZ
All i did was apply the updates my truck most likely never got a single update since it came off the lot in 2021 lol
m_bt54
Bryan
Massachusetts
IT Director
Ah ok. Just trying to make sense of it. Thanks
Way2qk4u2c
Michael
Austin
2022 F-150 2015 Mustang GT
Network admin
I have this same issue. Updated everything through FDRS and made the forscan changes and now blue cruise won’t even engage and lane centering assist not available.
I have a 22 power boost.
I do have a dtc in the Ipma for digital camera which I believe needs the recalibration. I haven’t done that yet.
rugedraw
Javier
Miami
Auto Sales
Your truck has been reporting that code for the past 60 days which is as far back as codes get recorded. That's not it. We don't know why this IPMA software does not play nice with some PowerBoost trucks.
m_bt54
Bryan
Massachusetts
IT Director
Will be happy to do whatever it takes to be part of the solution to figure it out
mattmohr10
matthew
ohio
2021 F150 Platinum PowerBoost
Hello, I’m new to this forum and an f150 owner. I’ve been reading this thread and having similar issues. I recently purchased a 2021 f150 platinum with the BC prep kit. On my way home from the dealership I noticed the alarm on the cluster that lane centering was not available. Since then I’ve had the truck at the dealership to get all the updates need to get the BC active (previous owner never had it done). Once I got it back the lane centering or the BC isn’t working and BC isn’t showing up in my Ford Pass App as a connected service.
VIN #1FTFW1ED1MFC04495
Any help would be appreciated, thanks.
rugedraw
Javier
Miami
Auto Sales
VIN #
It does not appear like the truck has an active BC subscription. Being a 2021, the 3 years it came with for sure is expired by now. As far as lane centering not working, the newer IPMA software requires the seatbelt to be plugged in for it to work. If you were not wearing it, try clicking it in and if still does not work, lmk.
mattmohr10
matthew
ohio
It’s not showing up on my ford pass app to be able to activate it. I’m assuming that might be a connected service issue then.
For the lane centering issue I do wear my seatbelt while driving.
