Sojourner
This is a FANTASTIC thread. TY, @FirstFord for starting it. And TY, @HammaMan for all the info in your replies!
Absolutely worth watching/bookmarking. ?
Thanks, but I really can't take that much credit for it - it was @Korça 's idea, and I just started heading down the rabbit hole....This is a FANTASTIC thread. TY, @FirstFord for starting it. And TY, @HammaMan for all the info in your replies!
So, in the end, this idea may not work that well after all - that is, it may not be practical. It sounds like you have to wait in a hot or cold truck while this specific module takes its time to power down - or don't wait, and trigger a DTC. Neither option is very attractive.....Yeah, the truck doesn't go to sleep immediately upon power down. Some modules do go to sleep once the door is open, but quite a few don't.
^^ Did you edit and add that later??? I swear, I didn't see that originally! Or am I just getting a little nuttier?You can have the truck in run, driver's door open, you on passenger side, hit power down button, pull fuse within 10 seconds. Close up the truck for ~10m or so, come back, put the fuse in and then start it up and see if it's mad.
Another avenue, turn off the truck, open/close driver's door, leave open passenger door, leave it for 10 minutes, go back out pull the fuse (after 10m has passed). Close passenger door (all doors closed), immediately open passenger's door, put fuse back in, go back to driver's side and start, are there codes? (determining logic potentials, the accessory delay circuit can be used to keep the shifter live for xx minutes)
That fuse also kills the door window control switch (drivers) so you may see an error for that but it wouldn't be there w/ the disconnect option.
Yeah, to clarify the variables to check. Sometimes what I mean and say can differ slightly so I edit to remove ambiguity.^^ Did you edit and add that later??? I swear, I didn't see that originally! Or am I just getting a little nuttier?
Whew - that's a relief. I thought I was on my way to losing it....Yeah, to clarify the variables to check.
SSN?I've triggered SSN and SVS. SSN is a more serious error that must be cleared for it to work.
I don't like making my truck mad.... but I'll take a crack at this (likely tomorrow).You can have the truck in run, driver's door open, you on passenger side, hit power down button, pull fuse within 10 seconds. Close up the truck for ~10m or so, come back, put the fuse in and then start it up and see if it's mad.
Okay... this was interesting....Another avenue, turn off the truck, open/close driver's door, leave open passenger door, leave it for 10 minutes, go back out pull the fuse (after 10m has passed). Close passenger door (all doors closed), immediately open passenger's door, put fuse back in, go back to driver's side and start, are there codes? (determining logic potentials, the accessory delay circuit can be used to keep the shifter live for xx minutes)
). On the other hand, it reinforces my earlier thought that adding a hidden switch may not be practical after all (sitting in the truck, watching the clock when it's 15 degrees out, or 102 degrees... ?), unless some kind of delay timer could be accompanied with the hidden switch - you flip the switch, and the action of breaking the connection is delayed by 10 minutes (and it seems to me the timer itself would have to be powered...). I see that such delay-timer components exist, but I have never utilized one or know much about them, and I'm not sure as to how it should be wired....No, I have not tried that series of actions. I have pretty much been following @HammaMan 's direction (he knows this stuff a million times better than I do....).I may have missed it but did you try the route of
Shut the truck off
Pull the fuse right away
Walk away and lock
Come back unlock
Install fuse
Start truck
See if it triggered anything
This routine would be as if you installed the shut off switch the way you want it to work.
