Ajzride
Ajzride
Automation
Are all MY 2024s incompatible due to TRON or was it introduced at some point in production? Looking at trading in my MY21 but don’t want to lose BP.
All
hpwjr
Howard
2023 F150 Powerboost Lariat
Administration
I’m at the tail end of a 2500 mile trip almost completely towing a 7500 lbs trailer. BluePilot makes a world of difference. I have encountered something new. Three times the Comma began to beep as if I were distracted and kept doing it even though I was plainly looking at the road as usual. It would not stop until it shut off the BluePilot. Even sliding the unit out of its sliding mount and plugging it back end would not cure the problem. It would eventually come back to normal. No idea why. It happened three times. Otherwise it was wonderful.
Ajzride
Ajzride
Automation
Sounds like a corrupted install, or a hardware failure might be starting to set in. When you get home I would do a full factory reset to try and clean up any corrupted disk segments.
dadaist
Tampa Bay
Ford F-150 Lariat Powerboost
Finally installed the comma and Blue Pilot 4.0 FOF model. It was a bit of pain updating the comma firmware and get the latest stable released Blue Pilot installed on the hardware.(OP Guidance at first page and his videos helped a ton) 🙏 Further, it has been a breeze to cruise on highways, stopped and go city traffic since.. I suggest everyone to get the latest mount which makes things so much easier. I wonder if the slider area on the mount can glow in the dark ? It is a very minor thing but I found it difficult to catch the slider groove in dark. Thanks again.
Ford F-150 Introducing Bluepilot! A Ford specific fork for Comma3X / OpenPilot IMG_4031
Ajzride
Ajzride
Automation
It won't take long and you will develop some muscle memory to be able to dock it in the dark.
Carnious
Kevin
Red Deer Alberta Canada
2025 F150 XLT 302A
Aircraft Maintenance Engineer
Anyone know if there is work being done to allow 2024 and 2025 models with comma ai? Or will that never happen?
Ajzride
Ajzride
Automation
There is one guy sort of working on it, but he is a college student and to be honest cracking TRON would just be a side effect of his final goal. It's a long shot.
hpwjr
Howard
Administration
I’m back on WiFi now and need to do a full factory reset but find no button for that. I found uninstall SunnyPilot but no factory reset. I suppose after a factory reset that I reinstall SunnyPilot and BluePilot? Anything else I need to do?
hpwjr
Howard
Administration
I’m back on WiFi but can’t find a button for factory reset. I’ve found uninstalling SunnyPilot. Is that it? After the reset I’m imagine I reinstall SunnyPilot and BluePilot or is there anything else I need to do?
Ajzride
Ajzride
Automation
Yes, just uninstall sunnypilot
then when it reboots enter the BluePilot URL.
hpwjr
Howard
Administration
scott011422
Is there a way to power the Comma3x in the house? Kinda wanted to get everything installed and learn the layout a bit before installing.
Ajzride
Ajzride
Automation
