it wouldn’t be very good encryption if a few amateurs on a forum could crack it.Oh dang - - - ok so I guess that means that unless we are able to break the encryption, this won't work on 24+ models of any ford truck.... Can we break the encryption? I'm happy to help.
Switch to staging, it has the latest anti-ping-pong logic which is tunable to your liking.Anything I can do to fix the ping ponging?
you have to go into the menu and sign into sunnylink using a GitHub user name.On my screen on the left sunnylink is orange and says error?
What link did you use to activate the comma? Bit.ly/bp-stable? or Bit.ly/bp-staging? (if you dont recall, check the settings, if there is a ford menu tab, then you are on staging.)How do I switch to staging, there’s no option that resembles that.
Menu --> software --> check for updates
then
Menu --> software --> target branch --> select
then
Menu --> software --> download
then
Menu --> software --> install
That's all model-driven and independent of the bluepilot enhancements. It also appears to be completely random with regard to when it is better or worse.The first couple tests on stop signs are going way the hell better than they used to. I’m getting full stops and making a little slow on starting back up, but that’s not a big deal.
Haha, well, I think I flipped off DA by accident after the upgrade to Notre Dame. That migt be why hahaThat's all model-driven and independent of the bluepilot enhancements. It also appears to be completely random with regard to when it is better or worse.
Vehicle has to be turned off and you have to be connected to wifi. You might could jump straight to "select" if the branch is cached.
