I have 2H/4H/4L, where is 4A?
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
There's really no reason to select 2H at all and I'm surprised they even left the button in place.
There is. One word. Burnouts..... :D
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
so how many guys we got that have successfully added 4a onto their XLTs now, like 3 or 4? mix between lariat and raptor cases? i'm still watching you guys work out the kinks before i tackle it on my job 1 21.
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Automotive Technician
There are a few different variables with this swap that create dozens of different potential configurations. I certainly wouldn't argue that each and every potential swap configuration has had all the kinks worked out, but if you stick with a configuration that Ford offered from the factory, the swap is fairly straight forward. The biggest hurdle for most people is just determining which parts they need and what specific configuration they want.
It's simple for TOD. Going with a raptor/tremor style to PB requires a custom driveshaft I believe since there's no factory option for the length required when PB+hi-loc are variables.
You need the ATCM (switch near driver's right knee)
The 21 lariat TCCM
and the TOD transfer case.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
thanks. already have switch and tccm. will pick up case at some point.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
The 21 lariat TCCM
on the driveshaft piece and raptor case...wasnt it decided that 6.5s did have that issue?
Mosey
2021 F-150 Powerboost
Hey all you smart guys, can I install the 4A dash switch now without either the TCCM or TC? And will the ESOF in my XLT continue to function?
isthatahemi
Trevor
2024 Platinum 703a Mag Grey PB
Owner
Okay, I’ll bite, why would you do this?
Yes. The ATCM units have the same circuit boards. The unit installed in the non 4a switch is just a blank non-operational button. I took apart my ESOF unit and found the circuit board to be the same unit as the one containing the 4a button. Just 2 cheap plastic parts would be enough to convert the ESOF ATCM into the 4a unit. If you're doing an HVAC module swap, it's the perfect time to toss in the 4a unit if you plan on doing the conversion.
isthatahemi
Trevor
Owner
Doesn’t the switch pop straight out on these trucks? My recollection from having one apart (2 years ago) is no disassembly required for this switch, just gotta force it out.
SALEEN961
Radnor, PA
2021 F150 XLT 302A
With the right trim tool, you could probably pop the switch out and replace it in under 60 seconds. If you remove the center console trim to press in the tabs on the back of the switch and carefully push it out, it still only takes a few minutes to replace.
Mosey
Thanks. I have taken the dash apart in the past for the hill descent upgrade, but that was a lot more complicated.
isthatahemi
Trevor
Owner
K - that’s what was thinking, also why I was wondering why someone would change just the switch. (Not directed at you, just closing the loop on my comment).
Mosey
No worries. Legit question.
