ahparker
I'm sure this is very simple and obvious, but not quite understanding tow weight vs payload as it concerns engine stress.
I understand that roughly 10% of trailer weight goes to tongue weight and counts against your payload capacity, but is pulling the same weight, say 1k#, whether on a trailer or in the bed the same amount of work for the engine? Or put another way, IF payload was magically 7k# and that load fit in the bed, would that be the same amount of work vs towing a 7k# trailer? Just thinking about a 2.7 max tow rating and trying to understand better (I know you probably shouldn't pull 7k# with a 2.7).
Or is there some magical formula that changes the amount of work to be done when weight is pulled on a trailer? It seems like it would all be "sprung mass" as I understand it.
Hopefully this question makes sense and thanks in advance for responses!
