yaojunliu
您需要整个 SCCM 组件,而不仅仅是单个时钟弹簧部件。如果那是他让你得到/发送给你的,那是错误的。
ML3Z-3F791-BB
Column Housing Assembly 应该是每个人都应该订购的唯一 SCCM。不仅仅是发条本身,不仅仅是 SCCM 本身,您需要整个 组件!
[/引用]
是的,它需要整个程序集,而不仅仅是 sccm。我添加了一个加热轮和一个硬按钮。我只有一个加热座椅。现在的问题是加热座椅不加热。加热轮非常易于使用
ML3Z-3F791-BB
[/引用]
Ah if you only have an XL then you don't have auto climate either which is a totally different HVAC module. That might be part of the problem if I understand you right. What does you current and new HVAC controls look like?我的车是 lx,只有加热座椅。我已经复制到新模块中了,试了试还是不行。最后,我更换了旧的,它可以工作了。我觉得它不适合我的座位,
好的,加热轮工作很划算。您是否将 HVAC asbuilt 从旧模块复制到新模块?如果你这样做,不知道为什么座位会停止工作。HVAC 或 DSM 是否有任何代码?
[/引用]
DSM 的代码不匹配
Ok, I recall you saying you had an XLT so then yes, you would have auto climate. What HVAC module did you get to replace it though? I wonder if having the cooled seat buttons on there as well is messing with something.只能加热。更换加热轮硬件后,加热轮正常工作。加热座椅屏幕显示自动温度调节关闭。其他一切正常
No worries, understood, I was just curious about superfordman more than anything. Hopefully he is helping you figure out whatever issues you haveTranslation, English is not very good
Have you tried enabling the soft button on the touch screen? I know this isn't what you wanted, but it may be your only optionI think the hard button with heating wheel is not compatible with my xlt without ventilation seat
My car has no cooling seats, only heated seats, and the automatic air conditioning are normal. The hard button heating seat lamp is normal. I don't have ventilation, so it won't light up, so I want to heat it nowAh if you only have an XL then you don't have auto climate either which is a totally different HVAC module. That might be part of the problem if I understand you right. What does you current and new HVAC controls look like?
Yes, my Google-lator-arin is very good ?@superfordman do you know mandarin or are you using a translator?
Ya this would be your best bet right now, use your normal HVAC controls but enable the side IOD climate screen like I did to control it.My car has no cooling seats, only heated seats, and the automatic air conditioning are normal. The hard button heating seat lamp is normal. I don't have ventilation, so it won't light up, so I want to heat it now
