Good random h7 battery
Parthery
Brian
Atlanta
2023 F150 Lariat 3.5
The Costco (Interstate) AGM H7 and H8 are the same price ($179.99).
2Lazy2P
PNW
Il Dolce Far Niente
I just installed the Costco Interstate H7. Great price and installation was a breeze using the existing hardware. Did have to buy a larger blanket but no biggie.
VRFlyer
Chase
MDW
2023 XLT 3.5EB SCRW FX4
InofoTech
Spiffy
Usa
2022 platinum powerboost
Did it fix anything?
2Lazy2P
PNW
Il Dolce Far Niente
Well, it’s only been 5 days and there have been no issues. I did throw my NECO5 on it before the installation to ensure it was topped off and have not used it since. Very light driving on local roads. 50 miles total @ 30-50 MPH. So if there is a draw down I expect to see it at some point. The old battery would have already affected the remote features.
Calson
Monterey CA
There are only a few brands that offer full replacement if the battery fails within the first year or two of use. Most provide a pro-rated credit toward a new battery. I bought the Optima yellow top where the full credit is available to customers.
Nevadajack
Reno Nevada
2020 Ford Explorer, 2015 Ford F250, 2022 Ford F150
Plumber
Just installed the Weize AGM H7 battery....$156 delivered and no core charge. H6 battery blanket fit the H7 with no issues. Will report back if there are any issues/problems with the Weize battery.
Spiffy
Usa
Have you done any tests? Like what is the resting voltage, after the truck is turned off and a couple hours go by or even the next morning what does the battery show.
Nevadajack
Reno Nevada
Plumber
No testing done. Actually, the auto start/stop quit functioning and I had the battery low warning on Fordpass. Decided to just swap the oem out after 3 years of use. So far, 2 ota updates have installed since the battery was changed and the auto start/stop back to normal.
Spiffy
Usa
OK thanks. I was just hoping you had. I've replaced my batteries. I am still experiencing low battery sleep mode.
If you pull the battery isolator out of the tray it holds an H8
Did you?
I'm tempted if/when I finally replace the underhood battery.
Which might be even longer from now since you convinced me to stick the LFP in the back. ?
