FordPass will not update
hpwjr
Howard
2023 F150 Powerboost Lariat
Administration
Today my FordPass app will not update no matter what I try. I’ve even finally deleted the app and reinstalled. It would not remote start either. My vehicle battery is a 12.9, so it’s okay. Any ideas?
SomebodyInGNV
Gainesville, FL
'21 F150 4WD 301A 3.5L w/ HDPP
In the Ford app, go to connected services at the bottom of the first page. Scroll down and go to contact us. Call the number for Alexa, etc. I've found them slow but helpful. If they're not the right people they'll connect you or transfer you to the people that are.
hpwjr
Howard
Administration
I got hold of Ford and they turned off connections in Sync and then had me turn it back on. No reset. They said it shows I’ve not communicated with the modem in two days, so I need to go to Ford. It’s possible a master reset of the modem might bring it back but it looks like it’s gone bad. Ugh. I have Ford ESP but it will take forever to get it going I fear. Not a huge deal, but I use the FordPass app to keep track of tire pressure, oil life and so on.
hpwjr
Howard
Administration
Well, last night it started working again and still connects this morning. Who knows? There’s little sense in taking it to Ford now because they’ll never find the problem while it’s operational. Thanks
Hans Moleman
SF Bay
Your TCU is failing. Mine is doing that right now. Sometimes it won’t work within one hour after the truck is shutoff. Then sometimes it will work for a whole day. And sometimes it won’t work even when the truck is on.
It has a sporadic trouble code for TCU Ethernet failure. Mine is at the dealer right now being checked out. I was not sure to bring it to the dealer since it happens intermittently. However they told me they saw the TCU failure in the history so said there is some kind of problem and are willing to take a look at it.
hpwjr
Howard
Administration
Can I retrieve any code with Forscan that would demonstrate a failing TCU module?
Hans Moleman
SF Bay
You should be able to but I used OBD Link and here is what I got
Ford F-150 FordPass will not update IMG_8580
HoustonScrew
Jorge
Houston, Texas
2024 Powerboost
Network Technology evangelist
Hold the radio power button and the FF button while truck is running, the radio will reset, no data lost and it should work after that. I had the same issue this past few days and that fixed it.
Worse case scenario, before I would ever hand my keys to anyone at a service department, I'd manually reset the TCU myself. It's behind the passenger side rear seat on the back cab-wall.
There's 3(?) harnesses, I believe. Unplug them. (Or maybe check them to see if they are well connected?)
Let it sit a few minutes and then plug back in.
Ford F-150 FordPass will not update Screenshot_20250924_113323_OneDriv
Ford F-150 FordPass will not update Screenshot_20250924_113215_OneDriv
Davexxxx
MO
Mine wouldn't load the other day. Restarted the phone, then it loaded but required a new sign in.
Figured it was an app update but don't recall which version it was before, so just guess.
JohnTrigger
MD
‘24 F-150 STX 2.7L SCREW
The TCU has capacitors that store energy and those take a long time (several hours, ~overnight) to dissipate as far as getting it to reboot from scratch after unplugging it.
CowboyJohn
East Texas
2024 F150 STX Offroad 5.0, 2015 Mustang GT 5.0
HS Science Teacher, former coach
My Ford Pass App stopped working on the 9th. I called the Ford Pass help line on the 15th and was told since my truck hasn't connected in over 3 days that I needed to take it in. I took it in on the 18th and was told they had reset it on their end. When I picked it up, it still wouldn't connect. I removed the app from my phone and reinstalled it, now can't get my truck back on the app, even with a really good cell signal.
I did notice that on the 9th when it quit working I also got a OTA for I'm guessing is the TCU.
The Code for the OTA was "TCU 25-25.2.5.9.1"
I wonder if the OTA is the culprit. While searching this Forum I have seen several others with similar issues.
If I try the unplugging the TCU method, should I disconnect the battery first?
JohnTrigger
MD
Battery (both if Powerboost) disconnect or TCU unplug for several hrs + would have the same effect.
CowboyJohn
East Texas
I don't mean to hi-jack this thread, but since it is being read I'm gonna add to it.
I went to where I had a good cell signal and tried to add the truck to Ford Pass again. Fail.
I called the Ford Pass helpline and after about 20 minutes they told me to call the Ford Tech. Hotline tomorrow during business hours.
I'm gonna unplug the TCU overnight and try again tomorrow before trying the Hotline.
Also what is kinda strange is that I have my son's 2015 Mustang on the App and it still shows up, however the Ford Pass helpline said it wasn't visible on their end. Maybe because the Mustang doesn't receive OTA's???
My Ford Pass app does give me notifications that the attempt to connect has failed.
I'll try to update as I go.
Also my TCU has 4 connections on the bottom.
Ford F-150 FordPass will not update Screenshot_20250924_203727_FordPass
Ford F-150 FordPass will not update 20250924_202941
Interesting.
Definitely looks like a newer design TCU?
If I had to guess they split the widest connector into 2 separate connectors, and the unit itself is flipped front<>back with some kind of heatsink added?
