The TCU update you got broke the TRON encryption. I've seen if happen countless times on 2024/2025 F150s that use TRON on certain modules within the network. The dealer can fix it in minutes.They also show they found Code: TCU U211B:51:0B Control Module Message Authentication
That's nonsense. There is only one OTA that has even been sent out to fix connectivity and that was to fix an issue where a TCU update changed the country code from US to another country rendering the modem useless, and wifi (or fixing it yourself with FORScan) was the only way to get that update/fix. The country code in your TCU is correct for the US; I had already checked that jic. They are clueless and talking out of their ass.Okay the Tech number I was given last night is for dealer issues.
They did put me on with Tech Support from Ford Pass again and after trying a reset etc... I was finally told that this is a known issue with SYNC and that it is currently being worked on with no solution as of yet.
I was also told that my modem is not responding, but the fix would be pushed out with an OTA and that I should still be able to get the OTA. I'm not sure how that will be possible, but I guess I'll see.
She said a statement (Service Bulletin?) was released on Aug. 29 about the issue.
I asked how many or what year models were affected, but she didn't have that info.
So I guess it's wait and see.
| SSM 54090 2021-2025 Various Ford/Lincoln Vehicles - SYNC4/Digital Experience - Unsuccessful TCU Software Update Or Software Activation During The USB Update |
| Some 2021-2025 Ford and Lincoln vehicles equipped with SYNC4/Digital Experience may exhibit an unsuccessful telematics control unit module (TCU) software update or software activation during a universal serial bus (USB) update. This may be due to the vehicle connectivity setting being disabled. To correct this condition, enable vehicle connectivity in the vehicle center display, select Settings > Connectivity > Connected Vehicle Features > Vehicle Connectivity > Toggle ON. Perform the update. If the condition persists, follow the normal dealer internal escalation process. After the update is complete, toggle the connectivity OFF in the vehicle center display, select Settings > Connectivity > Connected Vehicle Features > Vehicle Connectivity > Toggle OFF. NOTE: If the vehicle comes in with the connectivity settings disabled, connectivity must be returned to the disabled setting before releasing the vehicle to the customer. |
