My experience it works pretty well as it is but I'm not against getting it to run better. The post I saw on another forum they mentioned changes to the font.
I wonder if it's the so-called 'Unleashed' theme that can be enabled with Forscan.I'm curious what this new, clean design for the infotainment is.
Probably because so far only 2023 trucks are getting it. The change is likely minor so we might not notice it anyway.Why is no one with 6.3 posting a picture of the “new clean infotainment” screen ?? ?
Works fine for me.Anyone else finding PTS to be useless? The "Connected Vehicle Dashboard" will not load for me.
Well, shoot. Wish I knew why it wasn't working on my connection. Thanks for the confirmation!Works fine for me.
I've wanted the sheets to be cloud-based for some time.I didn't put together that you are one updating the spreadsheet, thanks for your help, its a huge benefit to the community. We should get @tonesto7 input as well, but I am wondering if we move the attachments to a live GoogleDoc, I am thinking we can somewhat automate the updating of the Github site relatively easily so its less of a burden to get that updated and could even give certain other members write access to the spreadsheet so they could contribute as well.
Could use a low-code automation tool to watch the googlesheet for new rows and transform in into the appropritate JSON, and do a pull request in github. then @tonesto7 would just have to review the pull request and make any necessary modifications.
Thoughts on this?
if you reboot your head unit twice, you should get an update (if needed). Then it will show up on the appI've never seen a software update show up on my app.
do you get this if you have automatic updates turned on?
Uh, no.if you reboot your head unit twice, you should get an update (if needed). Then it will show up on the app
