JB4No Powerboost -![]()
Unless you use select shift to lock your trans into a specific gear at 2500RPM, you may never notice the added torque. If you give your truck enough throttle to hit 510 lb-ft at 2500RPM, it is going to downshift to a lower gear unless you prevent it from doing so.Hoo boy, that torque difference at 2500 rpm will be noticeable.
Really depends on the strategy -- if they program it right, it could hold gears longer instead of downshifting if it's not a substantial load. Granted boost and fuel economy aren't friends, but 1st gear is pretty substantial. Especially for those w/ low 3.x gears. It won't turn an ecoboost into a PB, but it should still be pretty decent.Unless you use select shift to lock your trans into a specific gear at 2500RPM, you may never notice the added torque. If you give your truck enough throttle to hit 510 lb-ft at 2500RPM, it is going to downshift to a lower gear unless you prevent it from doing so.
Very fair point, but in my experience it's hard to hit full boost at 2500RPM unless you are being very deliberate. Hitting full boost at 2500RPM without using select shift just seems very unlikely because even at full throttle the turbos just don't spool up too quickly below 2500RPM.Really depends on the strategy -- if they program it right, it could hold gears longer instead of downshifting if it's not a substantial load. Granted boost and fuel economy aren't friends, but 1st gear is pretty substantial. Especially for those w/ low 3.x gears. It won't turn an ecoboost into a PB, but it should still be pretty decent.
It depends on how much the tune limits dual foot torque. The stock tune won't let you flash the converter too high, but I can easily flash it over 3000RPM with a tune.Though I didn't spell that out, I was envisioning a boosted launch, presumably in 4wd on on slicks. I guess it would also partly depend on how tight the converter is, though I doubt a factory converter would flash much higher than 2500, I could be wrong.
no it's vin locked. like they all are. upload the tune, remove the "tuner". you can leave it on if you wanna monitor stuff but that novelty wears off quickly IMHO.This might be a dumb question:l, but do you have to leave the river plugged in? What’s stopping someone from tuning, then letting their buddy tune?
Yeah I considered that, but it doesn't address the transmission, which in my opinion is just as important. The Ford programming for the shift behavior and response is pretty sad.
Keep in mind that MPT is advertising HP and torque numbers at the wheels, Ford is advertising numbers at the crank. That's why MPT's stock numbers are 354HP and 445 lb-ft. Their tune makes roughly 534HP and 605 lb-ft at the crank, that's way more than the Ford Performance tune.Any reviews in yet? If you look at the numbers is this just FPs version of MPTs 93-PRX tune, cause looking at it quickly it’s very comparable
I didn't fully understand this; can you elaborate?It depends on how much the tune limits dual foot torque. The stock tune won't let you flash the converter too high, but I can easily flash it over 3000RPM with a tune.
