gwb82
Thanks much. I read all of your threads and Hammerman’s. You guys are on a much higher intellectual level than than I when it comes to the tech on my truck so I read as much as I can in order to learn. Much appreciated! And I live in South Carolina, speaking only for myself here…I understand redneck all too well lol.I'm running the O'reilly Super Start Power Sport AGM Top Post Battery Group Size BTX14AH 220 CCA - ETX15 and the ECO-WORTHY 12V 20Ah Lithium piggyback with Cartman 4AWG 18-Inch cables.
The O'reilly battery is a fair bit taller and thicker than the OEM 7.5AH agm battery so some trimming needs to be done on the lower tray to fit it and on the battery itself so the terminals will bolt down. You'll need a longer bolt for the tie down strap to secure it and the lid won't completely close because of the increased thickness. I used black Gorilla duct tape to keep it down. Yeah.. I'm a redneck... I might end up swapping the bigger AGM out for a OEM sized one later on.
If you don't want to mess with all that then any parts house should have a direct replacement for the Ford BHAGM-AUX1-B auxiliary battery. You can then just get the 20AH or if you want more reserve capacity get a 30AH lithium cell instead. Definitely worth looking at Hammaman's testing an aux battery solution thread if you have not done so already.
