Big Dog Daddy
New Jersey
I had the same thing. Jesse suggested this change and it worked for me. All buttons now work as before. It adds the AUX camera to the view also.
7D0-01-02
AXXX XXXX XXXX
I made the change in forscan this morning and all is working again. Including the option for the Aux. cam!
Thanks
Bdubbs1198
Brian
CT
2021 F150 Powerboost Lariat
@Jesse-Infotainment can you check your block list to unblock me?
I forgot that he can't see this if I'm blocked, lol
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
Funny issue after updating my APIM to the latest version. While using Android Auto and Waze, if you put in a destination and start to nav everything will be fine on the screen until you go from full screen to standard then you lose the time to destination, the ability to stop nav and the ability to search. Is anyone else seeing this. The only way around it is to reboot APIM while driving and input the destination again.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Yes I noticed the same thing. I use wired android auto and when it happens I just unplug the phone and plug back in to reconnect and it's back to normal. Verry annoying!
CRFuzz
Cory
NY
2022 F-150 Lariat 3.5EB
DBA
Hi all, seems like the dealer is useless, so time to DIY. Is the VCX Vxdiag device still ok to use, other than the network scan caveat? With 500+ pages, want to make sure there isn't any new information I missed. Or if anyone is successfully using it still would love to know.
Thanks all.
Bdubbs1198
Brian
CT
From what I read, you are ultimately better off with Mongoose. There is some module update that I think errors out woth the Nano
Ajzride
Automation
Worse, the nano will brick (recoverable with a mongoose only) some modules.
CRFuzz
Cory
NY
DBA
Ugh, anyone in Central NY with a Mongoose? Worth a shot :/
PhilBurks
Phil
Tyler, TX
Website
philburks.com
2021 F150 Limited, all options is on order.
CEO
OK... here I go (2021 Job 1)...
  • New APIM dealer installed last week
  • Mongoose is all setup with my laptop
  • FDRS licensed for a year (don't ask)
  • Without connection to the truck, I can see the work ahead
  • Read hours and hours on this thread (THANKS THANKS THANKS).
  • Watched 3 YouTube videos
  • @Jesse-Infotainment in the wings to help if needed
  • Have 3 days off and HVAC set in my shop to 72°
So... onward....
Ford F-150 ECU module programming guide using FDRS F150-FDRS
dolsen
KY
2022 Rapid Red 701A
That might take you a solid two days NGL, surprised the IPMA isn't on the list yet, but I bet it will be once you start into it.
It could be because he didn’t scroll all the way down :p but yea all those updates will take a looooong time. I update 5 modules and it took almost 7 hours, and I don’t have a bluecruise truck either
Mike G
N. AL, USA
2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
A lot of those are 'coordinated' updates...so a lot of KOEO and clicking the OK button on the FDRS dialog...but it's not hard. Keep the powersupply voltage reading above 10.1 volts and bring lots of snacks. I don't see an IPC update in the list....so not that bad...
Remember any "emergency pull over safely, 911 not available, reverse brake assist not available, altitude low-pull up!" etc. messages you get while programming are all due to interrupted communications between the modules and are safe to ignore.
speedracercjr
Cory
2021 Lariat EB
O&G
Also remember to turn off your auto-wipers or the wipers will activate the entire update.
BHunted1
Sumner County TN
Every 30 secs for about an hour... lmao. First time I ever seen that happen.
jflottawa
J.F.
Kemptville, ON
2022 F150 Lariat
Director, Software Development
It's the "physical progress bar" (like the spinner mouse cursor)
