hotrodmex
Ca
22 Lariat 500.5a
It's a limitation of AA at the moment, it doesn't know quite what to do with the extra space on old AA versions. I ran into the same issue and was curious how the extended look would interface with AA. Doing some more looking, looks like the updated Coolwalk interface is right around the corner finally, hopefully...
What's even more maddening is the CoolWalk update is a server-side change that just has to be turned on, then AA versions from the past few months will change to the adjustable layout.
You can dot it right now if you root your phone and do some Hackerman action.
Ford F-150 ECU module programming guide using FDRS hacker-hackerman
Shoebox72069
MN
2021 F150 Powerboost Lariat
WOO! Finally updated that pesky BECM module. Even updated the BCM with no problems. Watching paint dry with the big APIM update...
I'm thinking that this could be one of my last software upgrade adventures since OTAs are working.... maybe.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Has anyone gotten by the TCU update error or is it a wait till Ford fixes the issue?
Ford F-150 ECU module programming guide using FDRS 1666814900726
Shoebox72069
MN
I just did the TCU update today and didn't have any issues. Could this be an issue with your As-Built data?
A few people have had issues with the TCU.
The ones that did I would send the usb files to them. They would install them and then run a PMI or config afterwards.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I would appreciate if you could send me the USB files for my truck. My VIN is 1FTFX1E81MKE01710. Would these files be the same for all trucks? Reason I am asking is that Billybob lives close to me and I know he is having the same issue.
Thankyou in advance
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just tried another update on the TCU and got the same error. Threw caution to the wind and did a PMI and said the module was not replaced. It went through the update and the software p/n changed from MU5T-14H090-BAY to MU5T-14H090-BAZ. The TCU disappeared from the update page. Am I correct in assuming that the TCU has the latest software?
If someone has any ideas if this is a work around for this error, please post, good or bad.
I DO NOT WANT THIS TO BRICK A TRUCK IF NOT CORRECT!!!!!!
ILL TAKE A LOOK. DID YOU CREATE A usb IN THE pmi PROCESS. jK IS THE LATEST SOFTWARE AND I BELIEVE BAZ IS APART OF IT.
THIS IS A BIT DRAMATIC. OVER A TCU UPDATE. YOU ARE UPDATED THOUGH THE TCU IS FULLY UPDATED.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Kanuck
Winnipeg, Manitoba
Retired Electrician
I only have the ACU showing.
ACM is showing but I wouldnt worry about that one, The TCU is fully updated so the PMI worked. as far as I can see youre fully updated
Kanuck
Winnipeg, Manitoba
Retired Electrician
remtiwk
Central PA
Would someone be willing to check my VIN before I pay another $50? :) 1FTFW1ED0MFA97746
