Spiffy
I personally think it's a coincidence. I researched the ground fault issue pretty thoroughly. You didn't say when this error happens. All the time or when you try to hook up to external power panels.
Thanks for the Response Jeff. It's pretty much all the time, I haven't had the need to even try and use the outlets yet (2021, new to me a couple of weeks ago).I personally think it's a coincidence. I researched the ground fault issue pretty thoroughly. You didn't say when this error happens. All the time or when you try to hook up to external power panels.
I have several DTC’s on my HCM, I think 4 of them are for the auto level, and 1 might be for the “module not programmed” or something like that. I can’t remember what they are off the top of my head and I didn’t take inventory of them. BUT this does not affect headlamp functionality aside from not auto leveling. I still have the turning headlamps, low beam, high beams, DRL’s, turn signals and even glare free is activated.Well thats disappointing, but overall not a big deal because, as you mentioned, functionality is not affected and no check engine light is displayed. This only hurts my OCD.
I wonder what is done differently when compared to when the HCM (Headlight Control Module) is added to a vehicle that did not have originally have one? They require programming before they will work, but to my knowledge, nobody has a DTC from installing one of these?? Perhaps @Jesse-Infotainment has some insight on this?
Anyway, thanks for the update.
Have you had wet weather/slushy roads recently? Some people report this when the wiring harness gets saturated.First off, thanks to everyone on this thread. I took the plunge and purchased the Mongoose, a windows laptop, power source, and the FDRS license to update a pretty big list of software. For anyone thinking about it, just go ahead it's not that difficult.
One question/concern: Ever since going through the process my Powerboost has been throwing up an error message stating a ground fault detection. Seems odd that this only started after going through the FDRS process. Does anyone have any thoughts/suggestions? I tried resetting, but the error keeps popping up. Coincidence?
VIN: 1FTFW1EDXMFB04914
Sounds accurate. It's great news that the functionality is working, but I will probably continue to find out if there is a way to avoid, erase, repair the DTC either way. It will be curious to see if when we get the ride height modules wired in if the auto level DTC will disappear? I assume it will.I have several DTC’s on my HCM, I think 4 of them are for the auto level, and 1 might be for the “module not programmed” or something like that. I can’t remember what they are off the top of my head and I didn’t take inventory of them. BUT this does not affect headlamp functionality aside from not auto leveling. I still have the turning headlamps, low beam, high beams, DRL’s, turn signals and even glare free is activated.
Yea that’s my assumption as wellSounds accurate. It's great news that the functionality is working, but I will probably continue to find out if there is a way to avoid, erase, repair the DTC either way. It will be curious to see if when we get the ride height modules wired in if the auto level DTC will disappear? I assume it will.
Little lost on IPC, I'm updating modules right now, but don't see IPC? Is that a other program? Where will I see that?I was thinking specifically when a bunch of us had F120 fail to load on our IPC and got stuck in liMbo. We had initially thought forscan changes to IPC had caused that. later several with no changes got stuck the same way. Your situation had slipped my mind. I have corrected my post.
IPC = Instrument Panel Cluster. If your truck already has the update you won’t see it.Little lost on IPC, I'm updating modules right now, but don't see IPC? Is that a other program? Where will I see that?
I know it’s tough to find help these days, but I think it’s time to let them go. Setting up a crack house at the job site is never acceptable.I had additional mechanics helping me last night luckily they packed their own lunch.
Send me your vin..Little lost on IPC, I'm updating modules right now, but don't see IPC? Is that a other program? Where will I see that?
1FTFW1ED7MFA74593. Thank you!Send me your vin..
Youre actually good. Your IPC is updated.. You are all set.. You should have BC in Ford Pass1FTFW1ED7MFA74593. Thank you!
Third time APIM shows as the only thing left on the download screen in forscan
The last two times it said successful but when I rerun the check, it's still the only thing there?
Just drove it and no Blue Cruise.Youre actually good. Your IPC is updated.. You are all set.. You should have BC in Ford Pass
