Kanuck
Winnipeg, Manitoba
Retired Electrician
Would someone mind checking my VIN?
1FTFX1E81MKE01710
I want to know what I have for update, so I can pick peoples brains if needed.
I am just waiting for the charger/power supply to be delivered. I have the mongoose plus and software installed on the lap top. Plan is to get a license on Saturday morning and get r done.
Mike G
N. AL, USA
1FTFX1E81MKE01710
Ford F-150 ECU module programming guide using FDRS 1FTFX1E81MKE01710-17-July-22
Kanuck
Winnipeg, Manitoba
Retired Electrician
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Can any one please check if there are any updates.. Thanks in advance
1FTFW1E51MFC37912
ZamoJoe
Joe
San Pedro, CA
2021 Ford F150 XLT Sport Appearance Lead Foot 5.0
So this is the list of updates I need on my truck which I am going to take care of in the next couple of days.
Can someone please let me know which top four are most important that should be updated first, and in which order to do them?
The rest I’ll do in any order
TIA
Ford F-150 ECU module programming guide using FDRS A8E35FB6-E815-4D85-B7AB-F1B8CB4A0323
Ford4Ever
Dennis
Oklahoma
18 Taurus SEL AWD, 21 F150 Lariat 502a
Could someone please run a check on my VIN: 1FTFW1ED5MFB53809
It was fully updated in April but I haven't updated in awhile.
ColoradoHunter
Dennis
2021 F150 King Ranch 4x4
Could someone please check and see where my F-150 stands as far as updates? Vin is 1FTFW1ED5MFC06184 .
Truck was repaired with CSP 22B08 on 14 June. I received 4 OTA's( up to 2.7.1) and the trailer recall OTA by the 27th. On the 30th I got two failure msg's on Fordpass for OTA 2.7.3. Truck shows 2.7.3 was successful. Am I stuck in place since Ford thinks I'm on 2.7.1 and the truck says 2.7.3? I've had scheduled updates set for every night since the 30th and have had my trickle charger on but have had nothing happen as far as OTA's.
Autofill
US
I can check in a bit after the kids are asleep.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Thanks Mike. Itching to get at it. Will do the PCM first and take it from there.
I keep getting a screen come up that is FlexNet Connect Client wanting me to down load VCI Software 1.0.1.16. Do I need this? It is 330 meg.
Mike G
N. AL, USA
I have installed it. I have also been told that I didn't need to install it and that my adapter would work fine without it. Another poster also found that he had to install it for his adapter to be recognized by FDRS.
If you have a message saying you need to install it, then I would install it. Worst case scenario, if you don't really need it, it hasn't hurt anything to install it anyway, Best case scenario, if the message was right, you have it installed.
Mike G
N. AL, USA
GSM and an IPC.
