JEB
US
2021 F150 Lariat PB 502a
Instrument cluster looks good. No DTC’s in IPC. only DTC I have is U2101 in the IPMA which I’m figuring is related to my pre-collision assist error on the cluster screen.
Have you made FORScan changes to the IPMA? If you have you need to have @Bob_Mac talk you through changing them back and then updating the IPMA. Once that’s done, you can turn back to the IPC. See if a new network scan clears the IPC offer.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Don't forget the IPC has 2 updates, the first a USB and second the CAN Bus... configuration is done in the CAN Bus update... let's see if he replies to the IPMA first
Skier167
Nate
2021 f150
I have and tried to restore my original backup in forscan but got a “configure structure mismatch”. Ironically my ipma update went through successfully and is no longer in my s/w updates list. Below is a screen shot of the error. I’m even getting it during a PMI
Ford F-150 ECU module programming guide using FDRS CED8E284-FE3F-4E82-9549-12B2BC3CBD8D
JEB
US
I haven’t forgotten. He said the USB went through fine and that it failed at the configuration stage of the CAN bus step. So he doesn’t need to do a full CAN bus reprogramming, which dupes the part he already did via USB.
Bob_Mac
Bob
North Carolina
He shouldn't have to, it will see that his USB went fine if it actually did...
Ajzride
Automation
@Skier167.
Problems with the IPC have come up before, particularly failure to configure. Some of that discussion, and the fixes, can be found beginning here: https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/post-181745
So my IPC is screwed up, has a U2100 which I can't PMI, and I can't configure. I keep being told to be patient, it will clear up. But looking at the link you set there, my as-built data looks corrupted, even though I am using a Mongoose.
I have
F120: MU5T-10F906-FDA (Correct)
F188: ML3T-14C026-CPB (Should be ML3T-14C026-CPC if it is on USB update or Mu5T-10F906-FCA if the Canbus update passed)
I'm suspecting this is why FDRS will not release the last APIM and GTWY to me, because my IPC is hosed up.
Now I"ve pulled this data from the widget, is there a way to get it from Forescan or FDRS?
JEB
US
He might end up having to do a CAN bus update. But I think it’s worth trying something more conservative first. I too had a problem with the IPC failing to configure and I ended up fixing it with a short PMI. His situation might be different, and if it is, he isn’t’ out much time trying a lighter touch first.
Skier167
Nate
2021 f150
change the 8 8A50 A218 AE51 to a 5
@Bob_Mac thank you! That cleared my IPMA DTC
for the IPC I compared it to the post Jesse made a while back and the first part of the update is up to date and it’s the 2nd half of the Ipc update I need to complete.
Bob_Mac
Bob
North Carolina
Try @JEB 's way first but I'm betting you may need to fail it and push the CANBus route and let it force it
Ajzride
Automation
I have
i answered my own stupid question, I can see the data in FDRS, it is corrupted there as well.
Ford F-150 ECU module programming guide using FDRS A52842B8-D459-430A-A367-2121D4CBB11D
Am I destined for a dealer trip? How the hell do I fix a corrupted module?
JEB
US
PMI!
