MaxMaster1
Maxim
Asia
2021 Ford F-150 Limited
Industrial Construction
Well, it's saying do the APIM which hasn't appeared. In a case like that (it's happened to me) I then do any other updates that can possibly be done. Then quit and restart FDRS which gets you a fresh network scan. Hopefully an APIM update shows eventually ?‍♂
Couldn't connect today. The account was blocked. The Internet connection is very weak, you have to reconnect many times. Ford probably thought I was a hacker)
MaxMaster1
Maxim
Asia
Run a PMI on teh Gateway.. Ill look at your vin.. but the new version of FDRS SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It doesnt submit data the same anymore. That is why a lot of updates remain.
PMI forces a submission of data.
If it still doesnt let me know.
Are the module with errors highlighted in orange? Is there no way to fix this update?
Jesse-Infotainment
Jesse
2024 F150 Lightning
Jesse-Infotainment
Jesse
2024 F150 Lightning
Explain what is PMI? I haven't seen this in the update modules.
In FDRS select the gateway module then on the side select programmable Module installation.
When asked if the original module is installed select no
MaxMaster1
Maxim
Asia
I opened the module (highlighted in red for example). All its features appear on the right. And from this list on the right, do I need to select the part of the module that needs to be updated and overwritten?
Ford F-150 ECU module programming guide using FDRS 2025-02-15 063913
farmtruckman
Dubai
2021 F150 Raptor
In the right side of the screen you see the PMI option, click on download, then run it, and as @Jesse-Infotainment said, when asked if you have the original module installed, select no.
Gord0
Gordon
2021 Lariat 502a
No, select gwm-programmable module installation. Do exactly what's Jessie told you to do.
Gerstein1989
Alexander
Toronto, Ontario
2024 F-150 Lightning Lariat
Plumber
has anyone had any issues purchasing a license for fdrs. keeps telling me my billing info is incorrect. tried every cc I had lol. Its my first time buying one.
Ajzride
Automation
some people especially outside the US have had issues. Sales are restricted geographically, not sure about Toronto.
poopy_pants
Brian
Wildwood, MO
2024 F-350 Super Duty
I’m in the US and I also have the same issue. I just called them and made the purchase over the phone. I wish I knew the root cause.
Gerstein1989
Alexander
Toronto, Ontario
Plumber
What number did you call. The number I called said they were closed. I called a couple hours ago
Kanuck
Winnipeg, Manitoba
Retired Electrician
I seem to remember helping a member in Ontario having the same problem. It was the address he used was not in the data base of the company checking the card. He had just moved to a new home in a newer area. He used his old address and it went through. Have you just moved to the address your at now. Also, make sure the address you put in is exactly how it is on your credit card.
Gerstein1989
Alexander
Toronto, Ontario
Plumber
I moved about a year ago but all my cc should have the current address. I’ll give my old one a shot. It’s worth a try
