Door Panel Arm Rest Replacement
NH-RCSB
NH
2025,F-150,RCSB,4x4, 70 Corvette, 67 Nova SS, 2017 Mustang GT.PP1, Jeep Rubicon
Hello, I have a 2025, XL, RCSB.
I'd like to replace the door panel arm rest. The XL has a hard plastic rest. I'd like to replace it with an OEM leather padded rest.
I haven't found a PN for this ? I assume it's a simple replacement ?
Any input would be appreciated.
Thanks
Porpoise Hork
Bret
IT Sys Admin
From what I am seeing Ford doesn't sell this part separately. You're probably going to have to either replace the door cards with one from an XLT or higher trim and move the existing hardware over to them or maybe see if you can luck out and find an XLT with the same color trim in a wrecking yard that are in decent shape for cheaper.
Je1279
Jared
Upstate NY
What @Porpoise Hork said is unfortunately correct. My dog tore up the top bit on one of my rear doors and replacing the entire card is the only option.
onlythetoast
Jason
Miami
2023 F-150 Lariat
jasonkosi
Jason
Chilliwack
2024 RCSB
You could also try local upholstery shops to see if they’d be willing to wrap your existing armrests. That’s what I’m planning on doing with mine since I still have some leather left over from when I did my seats.
National Superbike
Curt
Atlanta, GA
23 F150 SC 2.7EB
vintage motorcycle restoration
I have a STX and it has padded arm rests. They are vinyl and not leather but I'd rather have vinyl on my arm rests. So, you may be able to find some STX door panels on ebay cheaper than XLT or Lariat panels...
sbi
Upstate SC
Depending on your trim level, here is the link to find the part numbers for the whole interior door panel as Ford does not sell the those parts separately (though you may be able to find them on Ebay).
They start with the prefix NL3Z is for the Lightning and RL3Z is for all other trims:
https://parts.donnellyford.com/a/Fo...archGuid=7CEFE43C-334C-41D0-9E88-BB31886FFDF5
Thanks for the link. Unrelated to the subject, but this is the first Ford parts site that I see with detailed (and colored) parts diagrams like I've seen and used in other manufacturer for years. Bookmarked :)
