SALEEN961
- Joined
- Jan 1, 2023
- Threads
- 12
- Messages
- 653
- Reaction score
- 876
- Location
- Radnor, PA
- Vehicles
- 2021 F150 XLT 302A
- Occupation
- Automotive Technician
Over the weekend I finally got the chance to install my new intercooler and do some testing. The high/low numbers posted below are what I saw when starting a few seconds before the WOT pull section of the datalogs and ending a few seconds after the WOT pull. Both WOT pulls were started in 2nd gear and ended in 6th. As you can see, the ambient temps, coolant temps, and cylinder head temps were all slightly higher when I started the CVF titan V2 WOT pull, but the charge air temps and manifold charge temps stayed significantly lower despite being dealt this disadvantage. With the new intercooler I'm hitting the same desired air load at a lower boost pressure due to the reduce charge temperatures and increased air density. I did not lower the desired air load to make the CVF Titan V2 look better.
Stock Intercooler, lower grill shutters fully open: Cursor showing values at end of run
CVF Titan V2 Intercooler, lower grill shutters removed for clearance: Cursor showing values at end of run
Quality and Install review:
Overall, I’m very happy with the performance of the CVF Titan V2 intercooler, but the fit and finish could be better. When my intercooler arrived, it had a few minor scuffs and one ding. It’s nothing to get too upset about, but for $700 the packaging could have been better. I will also note that while the factory BOV did fit, the mounting holes did not line up perfectly and the sharp edges on the tabs that the BOV locks into did shave some plastic off of the BOV.
CFV does state that to install this intercooler you will need to remove your lower grill shutters, and while you may not need to remove the entire assembly, it will need to be significantly modified at a minimum. I have seen some people say that their intercooler fit after removing the extension the clips onto the back of the shutter assembly, but I had to remove the shutter slats and trim about 1/2” off of the shutter assembly to get enough clearance for the intercooler to not rub against anything.
