Str8Shooter
- #16
By the way, I have the Hybrid model and there is a second reservoir for a coolant system that holds 7.2 quarts that I think it is for the hybrid battery, but the owners manual calls it a low temperature cooling circuit. My dealership and quick lube center are only addressing the coolant for the engine that is 15.3 quarts but is called the high temperature cooling circuit. The coolant in both the high and low temp circuits are the same according to the owner manual in the capacities section.
What's the deal? I can't find anything else in the owners manual other than change the "coolant, which I assume is both the high temp and low temp circuit". How do I get these fluids changed properly for the low temp circuit too? References and not assumptions are greatly appreciated.
