Cold start - force engine start
Mosey
2021 F-150 Powerboost
Hey,
I have had my powerboost for two weeks and it bugs me to no end when the engine starts cold under load with zero lubrication. Call me old school but I would like to let the engine run under no load for at least 30 seconds when cold. I have searched around for an answer, and even went to two dealer service departments asking how - no luck.
So this morning while viewing oil change howtos it dawned on me that you would want to do an engine start after an oil change to insure there are no leaks and such. 30 seconds later I had the answer, hold both brake and floor the gas pedal, press start, and let off of the gas when it fires.
Sentinel1201
DFW
2021 F150 Powerboost
Is there any difference between engine starting when you press the start button versus engine starting when you are rolling slowly (under 2-3 mph) on EV power?
Not sure I follow what a "cold" engine start means and why one would be worse than the other.
Oxford_Powerboost
Austin
Northern Virginia
2023 F150 Lariat 5.0
No need to do all that. You can command the engine on any time by tapping the accelerator in park or neutral.
Fun fact, it doesn’t run the engine under load if it can avoid it when cold. It runs the engine, but uses the electric motor for torque for 30 seconds-ish. It also won’t use the engine to charge until it’s over 140 degrees coolant temp
thudnblunder
Bay Area, CA
2022 F150 PowerBoost
Cloud Software Architect
That sounds pretty well thought out! I guess that's another reason why they don't let the hybrid battery state of charge drop too low, it maintains a bigger buffer to be able to do this regardless of conditions.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I don't think that is correct. I've seen mine show "Engine On Due to Battery Charging" on the power flow screen before the engine was at 140°F in cold and warm weather. I haven't monitored the actual battery charge PID, but I don't think it would say charging if it wasn't.
Mosey
Mosey
By “cold engine” I mean an engine that has sat long enough to drop back to ambient temperature and all oil drained back to pan. Minimal oil film on bearing surfaces. I just want to let the engine run to build some oil pressure.
Mosey
Mosey
I will have to try that tomorrow.
hussar1683
SE TX
F150 PB (on order)
I believe most hybrids work in a similar manner. Don’t have my truck yet but was wondering if this trick works on the PB.
Oxford_Powerboost
Austin
Northern Virginia
It will tell you that’s the case. But watching the data (and by sound if you listen closely) shows it won’t apply a full charging load to the engine until it’s warmed up to some degree. Mine does show “engine on due to engine cold/battery charging” at this time.
My favorite message is “engine on due to: normal operation”
…thanks LOL
tbinmd
22 KR F150
The Powerboost eco has a 2 speed oil pump. When in electric mode the oil pump is run via electric motor, pressure is ~14lbs. You can check this with an OBD reader and monitor the oil pressure. If you look a the gauge on the dash, you will notice it's a little green nub, it's not at zero.
here's a post from snakebitten that explains it all with pictures.
#14
DarkSkyForever
MN
2018 Mustang GT, 2022 F150 701A (Ordered)
Software Engineer
#14
Precisely this. Forcing your truck to start the engine up cold is actually worse than letting it start the motor when it calls for it. The electric motor will be moving oil around for you.
#14
I'm not sure how that oil pressure that is reported by the PID during EV is created or maintained. It's true that the 3.5 Ecoboost has a variable oil pump, which basically operates in 2 different ranges when ICE is running, but that 14-15 psi reading in EV is below either of the 2 ICE ranges.
I haven't yet discovered if the oil pump is in play during EV. I don't know how it could be honestly.
What I miss with this Powerboost is the ability to perform a so-called flood start procedure where you can spin the ICE without starting it. I really wish I could find a way to do it after an oil change or after the truck has sat several days. But the traditional method of brake and full throttle just gets me a "ready" state in EV mode.
Are you guys saying you can force a fueless/sparkless rotation of the crankshaft?
Icecoldak
Steve
Alaska
2019 F-150 Limited
You need to get over 1900 technology and go with the flow!!! start it and go!!
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
Using the app to turn it on always send to keep the ICE running. That's been my solution.
