Brake Clicking
Mladen5375
Pittsburgh
2022 F150 502A Powerboost, 2023 Expedition SPP
Hey folks,
I just picked up my new 2022 Lariat a couple of weeks ago and just hit 1,000 miles a few days ago.
Recently I noticed an audible click when engaging the brake pedal while driving, at about the first inch of travel. It feels a lot like some sort of a relay, it makes an audible click and I can sense it on the foot as well.
Wanted to see if you guys have noticed this on your trucks or if it’s something I should get checked out?
WRS
Will
Mannford, OK
2018 F150 Lariat
Aviation
Yep, Dynamic braking with the electric motor. Hydraulic brakes Kick in when needed. You can see when each is active on the ECO coach screen. Green is Dynamic and white is Hydraulic brakes.
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
So, to answer your question, mine does the same thing. And I feel that this is more of a spring compressing “tink tink” than a relay. This sound has gotten louder over the 38k miles of ownership. 2 other trucks with same brakes do not make the noise nearly as loud.
Gabes
Jon
Hugo, United States
2018 F150 2.7 EB, 2021 F150 PB
Machinist
Mine does the same thing. Doesn't sound and feel right to me. Didn't do it when it was new, got louder all of a sudden.
Mladen5375
Mladen5375
Pittsburgh
I will take mine in when I get some time just to make sure it's nothing major
22XLT
IL
22 F150 XLT
Anyone else experience this clicking sound from under the dash when applying pressure to the brake pedal?
Seems to only happen once at startup up or per trip should you have not applied enough pressure while shifting into gear initially at first start.
mmdpg
Massachusetts
2008 Bullitt Mustang, 2021 F-150 Lariat
My 2021 Lariat has done it since I got it. Not all the time and sometimes very quiet or not at all.
jeffrt
Belle River, Ontario
2021 F150 Lariat, 5.0L
Mine does it too. Pretty quiet though, so I only notice it when the radio is low or off.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
MapGuy
Brandon, MS
2023 Ford F-150 XL; 2020 Ford Expedition XLT
Hey guys, I just got a 2023 F150 XL 5.0 V8 SuperCrew 2wd. I noticed this same click at almost exactly 800 odometer miles. Sometimes there is no click, some times it occurs with every single press of the brakes. Sometimes the click is barely audible, and sometimes the click is louder. I'm not sure, but I think sometimes I can detect just the slightest feel of the click. Maybe that feeling is just mental. Everything seems to function properly. Just that annoying click. I can get used to it if there is no fix or real reason to get it fixed or if this is just normal operating sounds. I love my truck. It's great, truly, but that click, though.
Like others have said, my truck makes the click about 5-10% depression of the pedal at speeds between above about 15 mph and below about 45 mph. I am most interested in what process is causing the click. When it's in the mood to click, I can rapidly tap the pedal and I hear the click just as fast as I'm tapping the brakes. My guess is it's a relay switch clicking and hopefully not some mechanical linkage clicking in the master cylinder or brake booster or some other physical part of the braking system. The relationship of the click and vehicle speed is what blows my mind. Will not do it at 60 mph and will not do it at 5 mph. And I have not confirmed, but I think based on the amount of depression of the pedal, the brake lights are on well before the click. Did anyone ever get an explanation or see a TSB for this? It's definitely not related to any hybrid system clearly.
Thanks!
Chrisprutw
AL
Thanks!
Just curious if you found out anything on this issue?
mkevans_ca
Halifax NS
2023 - F150 XLT Super Crew 302A FX4
Hi - I have a '23 XLT SCREW - doing the same thing - I feel two clicks - one 5-10% the other after about 25% - I hear a noise as well - sounds like an electric motor whirl like if you spin it without power. I don't feel anything different with my braking. This is intermittent - doesn't do it all the time. I also have some pretty good kickback on my brake pedal on cold starts - hold break - push button start - audible and can feel kickback. I have an appt tomorrow with the dealer to see what they say.
** Update post service visit **
they found a code in the EBB (brake booster) showing an error - replacement EBB is on order
Larry482
Rob
Massachusetts
2024 F150 Lariat
Just took my new 2024 Lariat in for the same type of clicking with the brakes. Did the EBB replacement solve the issue?
Dealer first lubricated all joints near the pedal. Clicking sounds were even louder following that. Then I was told they were not sure the cause of the clicking, but are confident it is coming from the EBB. I picked the truck up last week and they are replacing under warranty but told me the truck is likely not safe to drive b/c of everything the EBB effects downstream so they gave me a loaner.
Ford Motor Company
Ford
Dearborn
Hello, Rob. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to see how I can assist you with this brake clicking concern.
mkevans_ca
Halifax NS
The EBB replacement did seem to fix the issue of the multiple clicking and kickback on starting. I still have single click most of the time when braking but overall much better than before the replacement - best of luck with your issue - i hope it gets resolved.
