Icecoldak
I installed front and rear Z36 Power-stop kit with slotted rotors a few months ago on my 2019 and have not looked back! Very good upgrade. Look on Amazon, they have great prices and on sale a lot of the time.
One note -- verify your kit and the proper rotors were shipped BEFORE you begin!! I once had a kit that came with 2 front left rotors!I installed front and rear Z36 Power-stop kit with slotted rotors a few months ago on my 2019 and have not looked back! Very good upgrade. Look on Amazon, they have great prices and on sale a lot of the time.
they positively affected your brake performance 0%. You just reduced the rotor surface for your pad to bite into.I use drilled AND slotted rotors on my 350 and tow HEAVY. I have had zero issues with them and would recommend then all day long.
There's a whole lot more going on during braking than just surface area. Gasses roughly expand at a 1,000:1 ratio. The pads and rotors are an engineered pairing and work very well. I've come across several engineering designs that, from the outside looking in, appear to be less effective but are actually designed appropriately. Far exceeding what you'd believe to occur due to the entire system working as designed. Clearly the numbers powerstop is seeing on their brake dyno differ from your perceived value.they positively affected your brake performance 0%. You just reduced the rotor surface for your pad to bite into.
Where it does not lie is the race track. And there are no such designs in use on the race track. The only numbers powerstop are seeing are their bottom line. Its a marketing gimmick.There's a whole lot more going on during braking than just surface area. Gasses roughly expand at a 1,000:1 ratio. The pads and rotors are an engineered pairing and work very well. I've come across several engineering designs that, from the outside looking in, appear to be less effective but are actually designed appropriately. Far exceeding what you'd believe to occur due to the entire system working as designed. Clearly the numbers powerstop is seeing on their brake dyno differ from your perceived value.
Race cars don't use them due to the much increased stress on the rotors. Sorry. Using that as an excuse is the same as saying we use the same brand oil as them when they don't use anything similar.Where it does not lie is the race track. And there are no such designs in use on the race track. The only numbers powerstop are seeing are their bottom line. Its a marketing gimmick.
I'm sorry but you have that wrong. If there were an edge, the design would be used. No sense in arguing, spend your money how you see fit ?Race cars don't use them due to the much increased stress on the rotors. Sorry. Using that as an excuse is the same as saying we use the same brand oil as them when they don't use anything similar.
No sir. We use 5 20 oil because it is optimum for our engines. Race cars use oil that is as thick as water. My race boat had very little in common with a normal boat. Two different uses. We don't use race tires either do we? BTW, most high end sports cars come with drilled and slotted rotors.I'm sorry but you have that wrong. If there were an edge, the design would be used. No sense in arguing, spend your money how you see fit ?
Ok we can argue. I use 20w50 in my race engine which is toleranced for it by my engine builder. It's a boutique oil not off the shelf. My BMW has drilled rotors. My race car has 100 tread wear tires. The brakes are 2 piece slotted rotors with aluminum hats, made in USA. Running 4 piston brembos with aftermarket vented pistons, titanium shims and high temperature seals. I run Castrol SRF brake fluid which is ultra high temp. My brake rotors can glow red and I will not lose my pedal, lap after lap.No sir. We use 5 20 oil because it is optimum for our engines. Race cars use oil that is as thick as water. My race boat had very little in common with a normal boat. Two different uses. We don't use race tires either do we? BTW, most high end sports cars come with drilled and slotted rotors.
Might want to look at brake pad material. I have been using ceramic over composite for many years. It's just a thought.
Toss Bosch rotors and ceramic pads on it and be done.
+1 on semi-metallic. Ceramic pads are about low dust and NOT performance.You might be surprised what a new set of rotors, and Semi-metallic pads do for you. OEM Pads are a ceramic compound, and prioritize quite operation and low dust. Semi metallic pads will bite much harder, and provide more fade resistance, at the expense of more dust and potentially a bit more noise.
If the brakes on your current setup can stop the wheels from spinning/engage ABS, then you are at the maximum braking force anyway.
There are fixed caliper kit options available, but the advantage here is really only thermal management for repeated stops, towing heavy loads.
https://www.summitracing.com/parts/WIL-140-17000-R
Different use cases. A lot of race formulations need to be hot to perform. There are no free lunches.Where it does not lie is the race track. And there are no such designs in use on the race track. The only numbers powerstop are seeing are their bottom line. Its a marketing gimmick.
