Anyone install rear blocks?
JAGSarge
Joe
TEXAS
2014 Ram SCREW 4x4
Fed. Gov. Paralegal
Or how about enlightening the group with some education? I see all sorts of stories about guys that stack blocks on lift kits and then go hard off road and are disappointed. Having 6" of homemade blocks stacked is considerably different. Show me where under normal conditions that a 1" block, with dual locating pins, is unsafe. When someone else releases a compatible single block that isn't outrageously priced, I'll probably go that direction, but I don't anticipate having any issues in the interim.
If you haven't already, do some homework on stacking rear blocks guys and then decide if stacking is the route you want to pursue.
If you have & you're cool with it, more power to ya' ?
dre276
andre
NJ
2018 F150XLT, 2021 F150 XLT 302A Lead Foot
Here ya go
Have you installed these yet? The reviews on the website have people complaining that the provided u bolts were too short to install
Gen14
Midwest
2021 F150 XLT 302A
No, I went ahead and got the rough country kit instead and am just going to use their rear blocks. I'm out the cost of the Eibach kit. Plus the rough country 2" kit including the font spacers was cheaper.
tfrose
Tim
Louisville, KY
2021 F150, 5.0, FX4, Oxford White
I just installed the rough country 3” coil over lift. Well... Almost installed it. The block is only 2” to remove some the rake. Unfortunately, the U bolts the sent me were square and the 21 F150 is a modified square. Basically a somewhat circular square. Lesson learned? Make sure you have the right U bolts before you pull it all apart or you’ll find yourself putting t all back together with stock parts while you wait in the right parts. In RC’s defense, I ordered the 3” coil over lift minus the UCAs because theirs was on back order. They had to piece out the kit and apparently that is where the mistake was made. I used the fabtech uniball UCAs in case you’re wondering...
Clark
Regina, Canada
2017 Lariat, 2021 XLT
Mechanic
Yeah I posted a picture back on the first page of the new U bolts. I'm still waiting on a kit for just the rear, getting a bit impatient. Might have to get the RC kit and maybe sell the front blocks. With 3" in the front and nothing in the back towing isn't great haha
Gen14
Midwest
2021 F150 XLT 302A
[/QU
Yes I installed the RC rear 1" blocks. The Ubolts are correct with the RC kit (rounded top) and incorrect with the Eibach rear kit (Squared off Ubolts). +1 in the rear makes it look much better. Went on super easy.
StormTrooper2021
Wi
2021 F150 Xlt
Has anybody found a one piece block kit of at least 2 inches that have the correct shaped u bolts?
StormTrooper2021
Wi
2021 F150 Xlt
I reached out to Halo Lifts. They told me they have rear block kits for the 2021s. He said just to order the previous gen block but put in the comments that it is for a 2021 and they will send the correct semi round u bolts.
flynavy
Midwest
2018 XLT
Pilot
They make nice blocks, I had the nice shiny aluminum ones on my 18.
flynavy
Midwest
2018 XLT
Pilot
Anyone confirm correct u bolts for any other brand beside halo? They are 190.00 for their kit.
KTLW33
Pflugerville, TX
I am planning on doing a 2.5" level in the front & 3" blocks in the rear, I was curious what size wheels and tires are you all running on your '21 after with this setup? Does anyone have any before & after pics, would love to see how it turned out?
safety_3rd
Patrick
Austin
22 Powerboost F150 King Ranch
Bumping this. Anyone install one of the 3” blocks from stage 3? I’ve got the bilstein 6112 up front and 5160 in the rear and want some of my rake back for towing
NiftyF150
Tony
Minnesota
2021 F150 XLT Sport Leadfoot Gray 302a Ecoboost
Maintenance Supervisor
I installed MaxTrac 1" lift shackles in the rear instead of a bigger block. Not sure if it's true or not but I heard that taller blocks increase the likelihood of axle wrap. I was only looking for another inch or so of lift in the rear to get some rake back for hauling and the lift shackles accomplished that perfectly while retaining the stock blocks. Just some food for thought.
safety_3rd
Patrick
Austin
hmm haven’t looked into that. I’ll check it out.
