Android widget
bassaway
Louisiana
2021 F150 Lariat FX4 3.5L
I've noticed something unusual...
My widget has been failing to update automatically for some time now. I can go into settings and log into FordPass which immediately triggers a widget update, but subsequent updates never come until I perform another manual login. Is this behavior a result of the API changes or is something else going on with my set up?
kennelh
kennelh
Louise and Ken
Northern California
2021 Mustang Mach-E, Premium RWD
Do you have battery optimization turned off?
bassaway
Louisiana
I believe I did have battery optimization on so have since turned it off. I'm still monitoring but so far I think the widget is self-updating. Will keep an eye on it for the next few days.
Static
Dan
Kentucky
F150 - 2021 XL 4x4 Supercab
I had my 12v battery go bad and noticed the widget showed the LVB Status in red. After the battery was replaced, the status was still red until I reset the SOC in forscan. So does the widget get the actual SOC of the battery, or is it just a flag that says the battery is good or bad? The reason I ask is because it might be handy to be able to choose to see the SOC percentage instead of/in addition to the voltage of the LVB if that was possible. Just a thought.
kennelh
kennelh
Louise and Ken
Northern California
The battery info is pretty sparse; for example:
Code:
    "battery": {
      "batteryHealth": {
        "value": "STATUS_GOOD",
        "timestamp": "12-20-2022 11:22:44"
      "batteryStatusActual": {
        "value": 15,
        "status": "CURRENT",
        "timestamp": "12-29-2022 22:06:07"
The SOC (color and notification) are based on the batteryHealth value, and the display on the batteryStatusActual value. If the SOC is anything other than "STATUS_GOOD" it shows red.
Static
Dan
Kentucky
Code:
    "battery": {
      "batteryHealth": {
        "value": 15,
Ah, no problem, thanks for the info.
kennelh
kennelh
Louise and Ken
Northern California
Uploaded version 2023.01.22 to GitHub and Play Store. No major changes, just slight tweaks to the appearance of the widgets and some bug fixes.
Kanuck
Winnipeg, Manitoba
Retired Electrician
No word on Ford opening up yet?
Thank you for your work Sir.
kennelh
kennelh
Louise and Ken
Northern California
Uploaded version 2023.01.25 to GitHub and Play Store. No major changes unless you own a European Ford Focus, or would like to have more control over the units displayed in the widgets.
kennelh
kennelh
Louise and Ken
Northern California
Uploaded version 2023.01.27 to GitHub and Play Store. A bug fix for one important null pointer exception.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Thanks for your work...
kennelh
kennelh
Louise and Ken
Northern California
Uploaded version 2023.04.05 to GitHub and Play Store. The main addition is for Lightning owners: charging information is displayed similar to the change in FordPass 4.25.0. Note that this info doesn't update instantaneously; new info will only show when the car pushes an update to the servers.
I've only tested with with Level 2 charging but believe it will work with DCFC. If you find otherwise, let me know.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Is Ford still shutting down people using this app?
kennelh
kennelh
Louise and Ken
Northern California
I've had my account locked twice, but I was also using Recurrent so there's no way to know if that or the app caused the problem. I will say that I've not seen anyone who has downloaded it through the Google Playstore complain their account was later blocked. I'm recommending setting up a separate e-mail account through FordPass for the app to use.
