elcid98
Clover, SC
2023 F150 XLT 4x4 5.0
Escalation Engineer
Update. I'm way closer now. I can see it showing up in my dash but still getting a few errors. I dug a little deeper and thanks to AI I think I may have figured this out. My 2023 F150 XLT has a the following in the BCM forscan settings ASBUILT for
Module: BCM
Address: 726-16-01
Values: C110 4088 603D
88=EFC GAS • CC CRUISE_CONTROL
6=CMBB COLLISION_MITIGATION_GEN_2
I wondered if having CMBB COLLISION_MITIGATION_GEN_2 vs GEN_3 changes how I should set the
following value xxxx xx** xx-- 90 or "EFC GAS • CC ADAPTIVE_CRUISE_CONTROL_STOP_GO"
so I asked AI
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717279307520-n6
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717279342406-s8
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717279392085-nc
hopefully this works. I'm about to go test the change from 90 to 8C and see if AI is right.
88 = EFC GAS • CC CRUISE_CONTROL
8C = EFC GAS • CC ADAPTIVE_CRUISE_CONTROL
90 = EFC GAS • CC ADAPTIVE_CRUISE_CONTROL_STOP_GO
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Module: BCM
Address: 726-16-01
You should be able to set it to ACC with Stop and Go as all the other setting should allow that. I recall now, maybe someone else had to set it to Gen_3 as well, and/or maybe I did just messing around with things and set mine to Gen_3. But would makes sense since you have a 23.
If your CCM is showing up and everything is happy there now you must have got your wiring figured out. I follow now, you were prewired in the cab or engine bay, but not vice versa looks like. So that why you had to go straight from the CCM to IPMA essentially.
Wow! Your GPT deal is pretty fricken cool. Those are the best explanations I've ever seen of those as I've had to read between the lines for years to figure out what is what exactly and what all the acronyms mean. Do share if you can.
elcid98
Clover, SC
Escalation Engineer
thanks for replies... quick question on forscan settings. My Asbuilt shows the following settings for 702-02-01 (decoded with chatgpt)
  • FCTSRM OFF: Traffic sign recognition is turned off.
  • FCLKSMK ON: Lane keeping system marker keep is turned on.
  • FCLKSS Non_EuNCAP: Lane keeping system is not compliant with Euro NCAP standards.
  • FCDPACWRC Absent: Pedestrian and animal collision detection and response capability is absent.
Does adding the CCM module (part ML3Z-9E731-G) support FCDPACWRC or Pedestrian and animal collision detection? I was going to keep traffic sign recognition off too.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717340795961-qf
Je1279
Jared
Upstate NY
I believe you need the front BLIS sensors for the pedestrian and animal collision detection, but I could be wrong.
elcid98
Clover, SC
Escalation Engineer
for context my asbuilt 706-02-01 3267 E0CC 0156 with decoded meanings
32 = FCTSRM OFF • FCLKSMK ON • FCLKSS Non_EuNCAP • FCDPACWRC Absent
67 = FCDPACLPM Enabled • FCDPACPAD Enabled • FCDPACPAT Four_CH • FCDPACDAI Enabled • FCDPACTAI Enabled
E0 = FCDPACLTC Enabled • FCDPACROT Full • FCDPACFOT Disabled • FCDPACP False • FCDPACFCP False • FCDPACSCP False
FCTSRM OFF: Traffic sign recognition module is turned off.
FCLKSMK ON: Lane keeping system marker keep is enabled.
FCLKSS Non_EuNCAP: Lane keeping system standard is set to non-Euro NCAP.
FCDPACWRC Absent: Pedestrian and animal collision warning and response capability is absent.
FCDPACLPM Enabled: Lateral pedestrian and animal collision protection is enabled.
FCDPACPAD Enabled: Pedestrian and animal detection is enabled.
FCDPACPAT Four_CH: Pedestrian and animal collision prediction uses four channels.
FCDPACDAI Enabled: Driver alertness indicator is enabled.
FCDPACTAI Enabled: Traffic alert indicator is enabled.
FCDPACLTC Enabled: Lateral traffic crossing detection for pedestrians and animals is enabled.
FCDPACROT Full: Full range object tracking is enabled.
FCDPACFOT Disabled: Forward object tracking for pedestrians and animals is disabled.
FCDPACP False: Pedestrian and animal collision prediction is turned off.
FCDPACFCP False: Forward collision prediction for pedestrians and animals is turned off.
FCDPACSCP False: Side collision prediction for pedestrians and animals is turned off.
elcid98
Clover, SC
Escalation Engineer
Thank you. This makes sense now. I verified using my asbuilt that I only have the rear blis sensors
my asbuilt
706-02-02 xx*x xxxx xx--
8041 0200 00D4
decoded as
FCBLISRR Present • FCBLISFR Absent • FCCCMCR Absent
my custom chatgpt
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717343151355-cu
elcid98
Clover, SC
Escalation Engineer
Thanks I wouldn't have even attempted without reading all your notes and posts. Thank you. Currently I have it recognizing the CCM in the dash but I'm still throwing 3 IPMA DTCs that may have something to do with my forscan values or I could actually have a short in my wiring. I de-pinned the 4 wires from C134 and spliced directly to my CCM (using part of new harness I removed) because I needed to order the pins for C134.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717344373851-8i
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
my asbuilt
8041 0200 00D4
decoded as
my custom chatgpt
You need to have the CCM configured as present as that is what you added.
You might also need to have TSR enabled in the the IMPA for everything to be happy. You leave it disabled in the IPC.
elcid98
Clover, SC
Escalation Engineer
OK.. update. I looked closer at C242B and looks like even though I have the 4 wires in C134 they aren't connected to the IPMA (C242B). I guess it means if they exist it doesn't mean that they are wired to 242B...so in short I just need to go from CCM straight to the missing slots in C242B (IPMA). I'll need to buy the 4 pins, take the very very small C242B connector apart and hopefully not break anything and splice in my 4 CCM wires to the new pins and re-pin to 242. I think I saw the part numbers in page 20 or so of this forum post.
Here's a diagram that may make more sense. I don't see any other way to connect to my IPMA
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717535160783-uw
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717535186322-j
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Anyone pinned CCM straight to IPMA (C242B) using these pins and can someone confirm these are the right size DU2Z-14474-CA DU2Z14474CA Genuine Ford Part (fordpartsgiant.com)
Thanks
Yes, that's why you check this connector first and if you aren't prewired to it, you need to make your own harness to run straight from the CCM to this IPMA connector. Many have done it in the same scenario and looks like that what's you need to do as well. Yes those are the correct terminals you need.
elcid98
Clover, SC
Escalation Engineer
Thanks... sorry one more dumb question. So after I splice the pigtail wires to the CCM. Do these pins just insert into C242B or do I need to remove the retainer and take the connector apart at all? Looks like I can just plug them straight in to respective slots Terminal DU2Z-14474-CA | Ford Parts Center (fordpartsoem.com) .and they will seat themselves?
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1717599458630-4j
elcid98
Clover, SC
Escalation Engineer
Is this going in the right way or do I need to flip it…trying to figure out which way my 4 pins go in to my IPMA
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_2801
elcid98
Clover, SC
Escalation Engineer
I can’t get these pins to seat or click or anything …don’t think they are goin in all the way. Shouldn’t they click into place ??
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_2803
