5.0 Cylinder Deactivation
Hockeymandan13
Dan
2021 F150 XLT 5.0 302a
Also cylinder deactivation is not active in sport and tow haul drive modes. A tune can also make it so that it does not activate in normal or eco drive modes.
v8440
Iowa
'24 f150 xl rcsb
Urinal cake replacer
I can't tell when mine deactivates cylinders, so I guess it's not a problem for me. I'll take improved mileage anytime I can get it.
Hockeymandan13
Dan
I only noticed it once I added an exhaust system. It's very noticeable and quite annoying as a result.
MJG44
Toronto
Yes, aftermarket exhaust made the CD super obnoxious. Tuned out the CD along with other things that come with a tune.
Stealth88
2021 F150 XLT 302a
Aerospace
I have a Corsa sport side exit exhaust and hearing the CD activating/deactivating isn’t really that big of a deal to me.
Henfield
Usa
Did you measure based on fill-up vs odometer, or based on the dash computer? I also have 21 with 5.0, I do a lot of drives similar to the distances you mentioned and never went above 21.
Don't get me wrong - I am not complaining. I did not buy 5.0 expecting a Toyota Prius MPG, just saying that I never saw 24-25. Granted - I go by the computer.
I track every mile using the Fuelly app. I can comfortably live with 22 on the highway on summer fuel. Winter fuel will give you less. Summer towing 12-13 but winter 11-12. Everyday usage frequently includes short trips which kill mpg in any car. 18-20mpg.
  • Like
Reactions: sbi
TopOMichXL
Northern Michigan
2019 XL RCSB 4x4 , 14 th gen XL RCSB 4x4 on order
Carpenter/Boatbuilder
I can’t tell when it activates. What does it feel/sound like?
2024 RCSB, 5500 miles so far. 18.3 mpg average.
2019 RCSB 2.7 3.73’s. Traded it for the 2024. 71,000 miles 20.6 mpg. If anyone is interested.
v8440
Iowa
'24 f150 xl rcsb
Ya'll ain't gonna believe this shit. JUST NOW, my truck started misfiring, dropped a cylinder completely under load at least. Has one code pending, P3402. I found this on the internet:
Cylinder 1 Deactivation/Intake Valve Control Circuit Performance
So, I may have the board's first 5.0 cylinder deactivation problem. That said, it may well be something not plugged quite all the way in. I doubt it's anything very serious. I will be getting it to the dealer soon though.
JExpedition07
James
Buffalo NY
2023 F-150 STX 5.0L V8
On a positive note, even if cylinder 1’s VDE solenoid or roller rocker were to be acting up, it’s right under the valve cover and not a very invasive diagnosis or repair. Look forward to an update though.
I have seen 1 or 2 battery/ground issues on the boards throw this code, so your dealer may be chasing a short to ground or failed ground somewhere else. Good luck and hopefully you get a speedy fix.
v8440
Iowa
'24 f150 xl rcsb
I drove it some more today and it did not misfire. I think that if it does not do it again before the appointment that I will cancel the appointment. I think the chance of them fixing it with no hard code stored and no symptoms is low, and the round trip to/from that dealer is 50 miles. I will certainly keep the board apprised of what happens.
NavyChief
Orlando, FL
23 F350
Didn’t you just buy that truck?hopefully it was just a glitch in the matrix
v8440
Iowa
'24 f150 xl rcsb
Yes I did, to replace my still-getting-lemon-lawed 2025 ram laramie. Today there has been no sign of any trouble with the truck. Like you said, maybe just a glitch.
v8440
Iowa
'24 f150 xl rcsb
The truck has not misfired since the other day. At this point I'm going to cancel my service dept appointment for tomorrow as no hard code was ever set. Without a code and lacking any current symptoms, I can't imagine the technician would be able to pinpoint what happened. Hopefully it will not happen again; if it does, I'll make another appointment once a hard code is set for them to read.
v8440
Iowa
'24 f150 xl rcsb
I've still not experienced any more misfires, just as an update.
