RaacerX
Got my '24 F150 XLT Powerboost back in June 2024. Honestly, haven't been super thrilled with it overall for various reasons and I've been sort of worried about failures, although man, certainly fast as all hell.
Coming back from a couple thousand mile road trip at freeway speeds a few weeks ago, cold weather, I went to overtake someone and a few seconds later, pop; lost all power, engine light flashing, and the truck vibrated so violently I had to pull over for fear of losing control and couldn't even coast to an off ramp. ~8,000 miles. I was not towing and had maybe 500-600 pounds of gear in the bed, and I have no mods except for a mild Fox front level and some slightly larger tires.
App gave me "Major Powertrain Issues Detected", truck obviously in full limp mode, lumping at idle like a hot cam big block. Happened in an area without cell service and without an easy way to pull off the highway so I had to limp it a bit, Obvious misfires and no boost, no hybrid motor engagement, bad smell of burning rubber (like a clutch). I scan it and it's getting PCM codes, turbo underboost codes, random misfire and steady misfires on #6, etc.
Fast forward, get it towed down and dealer says a turbo wastegate failed and it over boosted, but sounds like they replaced both turbos. However I'm fairly concerned on whether a compressor wheel was damaged and whether debris entered the motor, or if the hybrid motor clutch or TC or whatever it uses lost life.
Would I be crazy to do a compression test on my own on #6? Or will I see some obvious DTC crop up if there was valve or cylinder damage on #6?
Haven't spent much time on the forums but Ford approved everything pretty fast, wondering if this is happening a lot? It also had a smathering of transmission codes too.
