rpmpest
Aust
Australia
F150 XLT 3.5 EcoBoost
Guys,
i need some help with my zone lighting menu, i enabled this a few days ago and while the functions work, the display is messed up (see pic, thats the actual screen not a reflection in the photo etc). The zone lighting is working and the screen if touched to activate a section does clear, but i know i should be seeing an image of the truck and not this weird blur. All other screens/menus work perfectly, it's just this one.
Changes I made as below - module>original value>changed to
APIM was reset a few times after updating the lines. Any ideas? 8" screen, XLT, Australian spec.
GWM716-02-013324-0104-007CxBxx-xxxx-xx
APIM7DO-01-035245-20F5-0087xxxD-xxxx-xx
BCM726-84-020000-0000-00B3xxx1-xxxx-xx
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet Untitled
MBabs382
Illinois
2025 F150 Lariat
If you have the paid version send your Logs off to Forscan and they can get it added and a test build sent back to you.
Any guidance on this? I’ve been all over their website and I see no information. Also within the software itself I can see how to save a log, but how to send logs to Forscan is not obvious to me.
SilverPigeon
Australia
Guys,
You know who I am ?. If you don't have mirror spotlights, try 9 instead of D in the APIM. Also check the HMI for it in the APIM:
360 Lighting Vehicle HMI (LVHMI) • IOD - Navigation (IODN) • IOD - On Board Generator (IODOBG)
7D0-01-04x*xxxxxxxx--
farmtruckman
Dubai
2021 F150 Raptor
Slightly controversial request, so apologies well in advance. Is there a FORScan change that allows typing on the keyboard when the vehicle is in motion? The keyboard access is blocked when truck touches 10kmph.
m_bt54
Bryan
Massachusetts
IT Director
This is high on my list as well but I’ve never been able to figure it out
farmtruckman
Dubai
2021 F150 Raptor
So here is a tricky one. Trucks in Middle East get a very orphaned TCU and as a result there is no WiFi connectivity on the truck and no personal hotspot.
Is there anything that can be done over FORScan that enables these features? Few folks seem to have found a way here in the UAE but pretty tight lipped about it unless you shell out $$$$$$$$$$ (emphasizing that they are greedy).
Scot Oregon
Scot
Central Oregon
2024 F-150 Lightning XLT
I just generated a 24 Lightning-specific IPMA sheet here so have a look at that
Thank you. When I match my As Built Data values for 706-01-01 they are the same as your prior IPMA (2024 - AB) *706 sheet, so that's good. What confuses me is using Ford's Connected Navigation, I do get speed limit signs popping up. (Maybe that's in the navigation vs. the car cameras actually reading the signs?), I do have 360 degree view which doesn't jive with MFCODCV Disabled (is this perhaps different than what they call 360 view?).
I will double check to see if the As Build data from Ford from my VIN actually matches what FORScan says I actually have in the car. I need to begin by backing up all modules, so I'll start there. Thanks very much for responding and all the work on the spreadsheets.
antho
Anthony
Houston, Texas
2024 Raptor 37
Guys,
@rpmpest
What do you have at 7D0-01-04 x*xx-xxxx-xx--?
EDIT: Missed that @SilverPigeon already spotted it.
rpmpest
Aust
Australia
The car does have the mirror spotlights and they do work when activated via zone lighting.
7D0-01-04 is currently set at -4-- which going by spreadsheet is
LVHMI Vehicle 2 (U725) • IODN Disabled • IODOBG Disabled
On the spreadsheet I see 7D0-01-03 also mentions zone lighting
7D0-01-03xxxxxxxxx*--0 =IODT Disabled • IODFE Disabled • IODZL Disabled • IODBC Disabled8 =IODT Enabled • IODFE Disabled • IODZL Disabled • IODBC Disabled
1 =IODT Disabled • IODFE Disabled • IODZL Disabled • IODBC Enabled9 =IODT Enabled • IODFE Disabled • IODZL Disabled • IODBC Enabled
2 =IODT Disabled • IODFE Disabled • IODZL Enabled • IODBC DisabledA =IODT Enabled • IODFE Disabled • IODZL Enabled • IODBC Disabled
3 =IODT Disabled • IODFE Disabled • IODZL Enabled • IODBC EnabledB =IODT Enabled • IODFE Disabled • IODZL Enabled • IODBC Enabled
4 =IODT Disabled • IODFE Enabled • IODZL Disabled • IODBC DisabledC =IODT Enabled • IODFE Enabled • IODZL Disabled • IODBC Disabled
5 =IODT Disabled • IODFE Enabled • IODZL Disabled • IODBC EnabledD =IODT Enabled • IODFE Enabled • IODZL Disabled • IODBC Enabled
6 =IODT Disabled • IODFE Enabled • IODZL Enabled • IODBC DisabledE =IODT Enabled • IODFE Enabled • IODZL Enabled • IODBC Disabled
7 =IODT Disabled • IODFE Enabled • IODZL Enabled • IODBC EnabledF =IODT Enabled • IODFE Enabled • IODZL Enabled • IODBC Enabled
On mine, 7D0-01-03 is xxxx-xxxx-x0xx. Should this be 2 instead?
SilverPigeon
Australia
@rpmpest Aust, @antho made a good catch there ? U725 is a Bronco platform. You want 0-3 P702 is f-150.
0 =LVHMI Vehicle 1 (P702 - FNV2) • IODN Disabled • IODOBG Disabled
1 =LVHMI Vehicle 1 (P702 - FNV2) • IODN Disabled • IODOBG Enabled
2 =LVHMI Vehicle 1 (P702 - FNV2) • IODN Enabled • IODOBG Disabled
3 =LVHMI Vehicle 1 (P702 - FNV2) • IODN Enabled • IODOBG Enabled
rpmpest
Aust
Australia
Thanks guys, that's interesting because U725 is the As Built. I didn't change it.
JEB
2021 F150 Lariat PB 502a
There is a FORScan change for this, but you probably don’t want to do it. It used to work with earlier versions of the APIM, but it is incompatible with later versions. Screws up the maps. Take a look at this thread. https://www.f150gen14.com/forum/thr...een-while-in-motion-disabled-by-default.9418/
m_bt54
Bryan
Massachusetts
IT Director
Scot Oregon
Scot
Central Oregon
May I ask you another question? I've been working through a thread from 2022 where a member added front proximity sensors to his 2021 King Ranch. Since my truck is a 2024 Lightning, I started with trying to decode the type of changes he was making. I took his "Change From" data and then looked at your spreadsheets to determine what features were originally turned on or off. For example: in 706-02-01 his 'Change From" was 7327-FFC4-016E and his "Change To" was 736B-FFCC-41FA. You have multiple tabs for IPMA, I used IPMA-706 but it has no "73" value for the **XX-XXXX-XX.
I looked at other tabs and one has a format of *XXX-XXXX-XXXX, but "7" wasn't an option. I'm trying to get my head around a methodical process that takes the member's starting configuration, compares the changes they suggest and then see if they make sense on my truck. Pretty clear you can't just plug in suggested member numbers from 2021 and expect success. Your help would be greatly appreciated. Thanks!!
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Ya they pretty much removed it from their website for some reason. Search around in the Forscan folders for the following two files, then zip them and email them to the Forscan guys and they can hook you up.
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1736569415212-gr
