Scot Oregon
Scot
Central Oregon
2024 F-150 Lightning XLT
What you have written in that document is correct, except that the end result has enabled more than you say; it also has enabled FCDPACLPM. I do not know why that was enabled by his settings because I haven't looked into what FCDPACLPM does. If you're looking to put 4 parking sensors in the front bumper and 4 in the rear bumper, then 8 channel is right. Door ajar indicator will appear on the sync screen when the camera view is on. Same for tailgate ajar.
My 2023 KR has that value as 6B also; eight parking sensors and displays the door/tailgate ajar on the sync screen, with FCDPACLPM enabled.
As I move on to the next line, I run across another test of my understanding. Would you mind looking at this and see if I'm doing this correctly?
Scot Oregon
Scot
Central Oregon
@Scot Oregon
FCDPACLPM is FeatureCfg_DPAC_LowPowerMode
a feature configuration for "Low Power Mode for 360 Cameras"
Thanks very much! Is there a source for a more thorough explanation of these? I'm using the AI feature of my browser and it's pretty good, but it's also pretty unreliable.
antho
Anthony
Houston, Texas
2024 Raptor 37
Unfortunately not. That’s all the info I have on it.
antho
Anthony
Houston, Texas
2024 Raptor 37
@Scot Oregon
What do you currently have here? The sheet you have attached is noted FF but your spreadsheet is from what? I see it doesn’t go to F on the first value of the sheet but why are you using that sheet specifically?
706-02-01 DATA: xxxx-??xx-xxxx
Scot Oregon
Scot
Central Oregon
@Scot Oregon
My truck if a 2024 Lightning XLT and Livinitup has added an updated IMPA tab for 2024 Lightning. I think it was on page 251 of this thread. I'm trying to bridge a project from 2022 where a member added proximity sensors to his 2021 King Ranch ICE. It may not bridge, but maybe it will.
My process is to take the 2021 AS Built and decode it using the IPMA 706 Tab and then take the changes the member said he made and decode them. Then I'm taking my 2024 Lightning AS Built data using Livinitup's new spreadsheet tab and decoding it. Then I'm looking at the changes suggested by the 2021 member. Some of the changes he makes are already part of my AS Built and some of his 2021 AS Built features are already enabled where on my AS Built, they aren't ..... SOOOO.
My inclination is to make all the features he has enabled and enable them on my truck and leave all the features I have enabled that he never enabled as they are in my truck (enabled). Basically, my plan is to not disable any of my features just because they weren't changed on the 2021 King Ranch. If that makes sense. When I get that far, I hope to ask the experts what they think of my approach. Then I'm going brick my truck! Hopefully not.....
Livnitup said:
I just generated a 24 Lightning-specific IPMA sheet here so have a look at that
SilverPigeon
Australia
Yes, E + 1F = FF. But answer @antho as he's working with you ?
jajatu
Madrid
Focus ST MK4.5
Hi all, I’ve disabled fake engine sound modifying ACM 727-01-01. It worked well changing the bit XXXX XXXX *X- - from 1 to 0.
Now I’ve tried to re-enable it again but it is not working. I’ve even tried to restore the as-built backup but it still not working.
SilverPigeon
Australia
Have you tried to reboot the ACM in service procedures (spanner icon)?
TMicallef
Terry
Trenton, MI
2022 F150 XLT
Automotive Supervisor
Getting ready to make a change with my turn signal blink count from 3-5. Can somebody explain what it means by "increase default value by 4 hex" please with a potential example?
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1736811557525-48
Also...does FORScan create a new profile every time I plug in? Sorry...newbie here. I see multiple profiles on other posts and curious how they're getting them.
SilverPigeon
Australia
You can adjust Lane Change Blink Number in the easier mode. Hex is hexadecimal, base16. We humans normally use decimal base10. Hexadecimal numbers go from 0 to F. So:
dec 10 = hex A
dec 11 = hex B
dec 12 = hex C
dec 13 = hex D
dec 14 = hex E
dec 15 = hex F
Therefore, if a value was A for example, adding 4 would make it E.
multiple profiles can be created if you say no to using one it already has and then it will do a full scan of modules, after which it will ask if you want to save that new profile. Most commonly, different profiles are for different trucks that have been worked on using that copy of FORScan.
peterefic23
peter
california
2023 f150
tech
Joekr5
Nowthen, Minnesota
2024 CCSB Lariat 5.0, Rapid Red, BAP
Hi folks!
I see in the latest version of Livinitup's spreadsheet that the ACM tab now only includes 21-23 MY trucks and there's no 24 tab shown. Did the ACM get rolled into a different module?
Bumping this one back up to see what happened to the ACM tab for model year 24. Thanks much!
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
No, its most likely all the same values as the previous years and has no changes if he hasn't released an updated tab, just hasn't changed the label of it
