MoodSwing
Pennsylvania
2021 F-150 Lariat Crew 2.7 turbo
Was playing around the adaptive learning stuff with FORScan to try and clear some driving learned previously and now I have an Adaptive Steering Fault with a steering wheel lit up on my dash. I have no idea what I did so I guess I’ll have to restore one by one until it goes out.
2022Bruce_L
Summerville, SC
2022 F150 XL RCSB
Noted should always save previous settings before making changes. If this is just taking a pic with your cell phone so you can change back as needed. Best practices.
Static
Dan
Kentucky
F150 - 2021 XL 4x4 Supercab
You can go into your drivers assist menu and turn lane keeping on and off if your vehicle is equipped. I believe it you toggle normal cruise control it will turn off lane keeping.
On my base xl I cannot turn it completely off, I can only change modes (aid vs alert) and sensitivity.
farmtruckman
Dubai
2021 F150 Raptor
Another doozy for me. When I change radio stations, there is an information banner that pops on the status bar showing the new radio station but the color of this banner is completely off from the theme. Anyone has fixed this? The same thing happens when I start the truck and I get the welcome message "Welcome NAME". Screenshots below:
This is the theme without the information banner on the status bar:
The status bar with the change message banner at the top (took a couple of photos so the color difference can be seen):
I will try to click some photos later this evening so the photos are clear and the color change is clearly seen.
BUMP! Uploaded some new screenshots where the color difference and the odd alignment is seen.
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1730924793880-q6
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1730924817313-h9
Did you turn on a special theme or something?
Some here use unreal or something like that.
I don't think mine is doing like you show in pic.
farmtruckman
Dubai
2021 F150 Raptor
Yes sir, I do have the unreal theme switched on but this happened even with the stock dark/light themes.
Bporourke2
Indiana
21 F150 Limited
Is there a way to change the splash screen in the instrument cluster? I changed the one on the sync screen but the cluster I can’t seem to find a way to change
SilverPigeon
Australia
Not that I'm aware of, but you can turn it off:
720-07-01xxxxxxxx*x--Mexico (M) • Splash Screen (SS) • Background (B) • DO NOT USE (DONOTUSETPMSPPD)
WTFover
Jason
Tampa
2024 F-150 XL RCSB
I mostly yell at computers for doing dumb things.
Hey guys, I have a headscratcher I was hoping to get a little help on. I bought a set of mirrors off marketplace with the turn signals and puddle lamps. My truck is a 24 XL RCSB. The mirrors were off a 23 truck and were removed for a set of Tow mirrors. I made the changes to the Passenger Door module to enable the puddle lamps and the turn signal lamps. Works great. I then made the same changes to the driver's side module and the changes don't seem to have any effect. Everything else still works on the new driver's mirror such as blind spot indicator, and mirror moves when commanded. I have reset the DDM back to factory, and then tried re-applying the changes with no success. Can anyone think of a reason only one side would work and not the other? It seems illogical that both the puddle and turn indicator on the drivers mirror would be faulty given their age and condition. Here are the parameters I changed on both lights:
740/741-03-04x*xxxxxxxx--
and
740/741-04-07x*xxxxxxxx--
Does Anyone have an idea of what could cause this?
SilverPigeon
Australia
@WTFover , at this point I would test operation of the indicators/puddle by physically connecting to the passenger side. If the hardware tests ok, there may be other config issues (type = bulb/LED etc.) to go through.
