powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
8 pm
still on
so i say its a workable code on the spreadhseet
powerboatr
powerboatr
Afyer powerpoint tested for 8 hrs
And check this morning
4 door openings and closings,
Long story on opening
Battery was at 62 SOC
From 95 at 2 pm yesterday
So powerpoint remained enabled.
The code does work
Livnitup
Livnitup
SoCal
2021 F150 Platinum
I added a mod to the common spreadsheet for enabling an extra brake light circuit wire for camper shell brake lights. Thanks @antho @powerboatr @Hickory
Damien
2022 F-150 Loaded Lariat 502a 5.0L
Automotive Dealership
Try it out and let us know:
PCM 7E0-162-04 x2xx xxxx xx--
Note: FORScan may display this address as 7E0-02-04
Didn’t work I went from x0xx to x2xx wrote and rebooted the module
scott011422
Scott
I've been looking, Is there a way to make the 3rd brake light flash when hitting the brakes?
Kanuck
Winnipeg, Manitoba
Retired Electrician
Electronic flasher mounted behind the light...
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Ha ya I tried that just for fun a few weeks ago and no go on my 23. Might be a 24+ option only or need some other changes someplace else, or just straight up doesn't work on a F150.
SilverPigeon
Australia
@Livnitup, has the CCM been decoded (there's no tab on your sheet for it)? Situation:
I have ACC enabled with Speed Sign Recognition, converted from NA to AU sign format. On my truck, the recognition works fine, but interestingly the truck takes no action on the recognition; it simply shows the sign and nothing more.
I actually love it this way as it just serves as a reminder of the current speed zone ?, but I was curious as to why it takes no action. I was thinking it might be of interest to others to achieve this configuration (which I have by luck or accident ?), in which case it would be a good candidate for a separate post.
Thanks for all you've done and do ?
P.S., what I'm looking for might not even be in the CCM, I'm just making an assumption ?‍♂)
P.P.S., I read in another thread that the Speed Limit Assist was the function that allowed the choice of wether or not the truck would take action on a speed sign; however, in my Speed Limit Assist sub-menu, the only choice I have available is Speed Limit Warning (not the same thing)?‍♂?‍♂?
Livnitup
Livnitup
SoCal
2021 F150 Platinum
The CCM only contains the vehicle VIN in hex so there was no reason for a spreadsheet.
SilverPigeon
Australia
That is identical to how my cruise functions. I turned off using the speed limit signs on purpose. Toggles for that are on APIM screen but if I recall in two separate menus for cruise settings.
