From my thread here... https://www.f150gen14.com/forum/threads/the-pbs-franken-frame-and-gimped-gvwr-sticker.13070/
The PB's "HD HEV" (4.4" width) frame uses the same .110 steel found on all of the heavier trims (3.6" width). The center section of it is reinforced beyond that of the HDPP frames only bested by the raptor's (6.6" width). The front end parts of both wheelbases are the same on the PB sans front spring thickness (img 2) where some obvious discrepancies are shown in blue regarding the HDPP package -- all springs are of the same material. The PB's front shocks are take from the diesel. A discrepancy in thickness vs performance can be seen.
The purple percentage number is the GVWR divided by the GAWR (axle ratings)
The maroon colored number is the sum of axle ratings
The golden number is calculated as taking the 96% percent of the GAWR (axle rating sum)
The beds and their method of attachment are the same, though come in different lengths based on the cab. The difference is frame / suspension. As to how the PB's frame specs were found was by caliper micrometer. The suspension spring specifics are on the door sticker as well as published in ford literature.
My mouse is a little jumpy today so mouse notes are scribbles :ROFLMAO:
Ford F-150 Which Ford F-150 Engine Is Best? All 5 Powertrains Compared Back-to-Back 1684264904741
Ford F-150 Which Ford F-150 Engine Is Best? All 5 Powertrains Compared Back-to-Back 1684266579392
Ford F-150 Which Ford F-150 Engine Is Best? All 5 Powertrains Compared Back-to-Back 1684266690999
JExpedition07
JExpedition07
James
Buffalo NY
2023 F-150 STX 5.0L V8
Frames get confusing, yield stength largely depends on the section modulus and type of steel used. Our F-150s have about 50,000 psi yield strength, and have quite a thick cross section in any variety. A C-channel frame is actually a good way to go if done right imo, more flex and no cracking, and no moisture retention. It was a shame Ford caved to those Chevy ads that pandered to uneducated consumers “see the truck go flexy” -classic Chevy move. Yet every single PeterBuilt and KenWorth hauling 50,000 pounds is a C-channel frame. Go figure.
I appreciate the strength of the boxed frame for sure, but I have no issues with a C-channel
Calson
Monterey CA
And exactly what qualifications and expertise does Ben Hardy possess? For engine stats I can go to Ford's website. For engine problems I can go to Consumer Reports and carcomplaints.com and similar websites and get actual numbers and a breakdown.
People like Ben Hardy give support to the old adage that in the land of the blind the one-eyed man is king.
In the past with model years (2016 and earlier) with large numbers of problems with engines it was primarily with the V-8 engine. For those with engine problems when towing it was primarily with the 2.7 turbo engine.
Mtnman1
Tod
2022 F150 RCSB FX4
I have always preferred V8’s over boosted engines. There’s a video from Town & Country Ford (I think that’s right) in Alabama where they poll all of the mechanics and sales people. It reinforced my V8 instincts.
I have been a GM guy my whole life and when I considered trading my 5.3 Trail Boss for an F-150, Granger’s pricing in an MSRP+ market flipped me.
I love the Coyote so far - zero regrets.
The coyote is so much better than thr chevy 5.3. That engine is a turd.
Uncle_Booty
Glen
Knoxville, TN
2023 F150 XLT 302A SCrew 5.0 157" 4x4
Commercial Truck Leasing
I've had 4 different vehicles with 5.3's ranging from 2004-2021. None of them ever gave me any issues at all. And simple to tune until 2018.
I like my Coyote a lot, though. It just makes it's power in a different rpm range. It does get better MPG's than the 5.3.
JExpedition07
JExpedition07
James
Buffalo NY
The Ford 5.0L V8 makes more power than the GM 5.3L V8 everywhere in the rev range. The power curves never cross nor touch. It starts narrow, and by 2,500 rpm the 5.0 is making significantly more power and the gap just widens more and more until redline. It only feels that way because the 5.0 has so much extra performance high in the revs where your 5.3 falls on it’s face and stops pulling, the 5.0 still beats your old 5.3 up bad in the low revs too, it just has a lot more to offer and keeps pulling as you rev. So It may *seem* that way but that’s not what dyno’s show.
Mtnman1
Tod
2022 F150 RCSB FX4
Yeah, seem to be reliable. But my god are they under powered.
No contest with the the coyote...thats why it is always compared to the 6.2, not the 5 3.
STX_guy2023
Ray
Navasota TX
2023 Ford F-150 STX 2.7 Eco
N/A
I will say this the 2.7 in a half ton truck is more than adequate, if you wanna do heavy hauling use an F-250 and up with a diesel. 325 hp and 400 ft-lb of torque with a 10 speed ratio is a beast compared to 20 years ago. why all the hate. remember when 200 hp and 300 ft lbs and a lousy 4 speed could do the job for a half ton and no one complained. we are living in luxurious times with 1st world problems I swear. My truck impresses me on the daily and have no complaints outta my 2.7.
I used to drive a 7.3 powerstroke F350 with 225HP/550TQ. Pulled my tractor and implements around with it and admittedly the chassis was built for it.
But dang is it amazing I'm driving around in a 1/2 ton gas V6 putting out DOUBLE the HP and more torque as well. All while doing so almost dead silent.
You do remember how not silent those 7.3 era diesels were? Lol
Yup, my dad refuses to get rid of his that's basically daily driven despite having no need for it. He doesn't do road trips. Tried to get him into a pro lightning. He said he doesn't want the payment and I did the math -- his current diesel usage washes with the payment, especially combined with his upkeep maint.
mxwrk
Max
Huntington Beach
2022 Lariat Powerboost
I miss my 7.3 Excursion every day. Most reliable motor ever made imo.
Samson16
Orlando, FL.
Aviation systems
Mine is!
Grafx36510
Rob
NY
I still drive a 2003 E350 cargo van with the 7.3 a couple times a week. Motor still going strong except for the turbo going kaput a few months back.
