What is the correct way to use your Pro Power to power a house through a 30A plug
mrichard02
Massachusetts
2024 F150 Power Boost Lariat
Looking to see if anyone has a correctly diagramed solution for plugging in a PB to a house to power a house through a 30A plug.
And so that the PB doesn’t trip through its internal GFCI.
tsigwing
DFW
2025 F150 PB
you need a transfer switch that switches the neutral and the hots
miniceptor86
Jim
McGregor, iowa
2014 F150 FX4 Ecoboost, ‘25 powerboost on order, ‘39 Ford Tudor Standard
tired
Best check with your electricity supplier. They will have an approved way to do this.
Severdog
Craig
Landrum, SC
Trader
I am changing out my main panel to accomplish this. You need to separate your neutrals and grounds on all circuits run to the panel, i.e. make the panel into a common "subpanel." This also implies that your neutral/ground bond is at the service entrance. Or you can cheat like many do and just cut the ground lead of the umbilical cord to prevent GFCI fault, since there is now no "double path" back through ground or neutral.
You can backfeed the PPO though a breaker at the top of the panel that has an interlock with the panel shutoff.
I plan to document this job with a video once I can get Duke Power to cut over from my old outside panel to the new one.
Hullguy
Jim
Weymouth, MA
2013 F150 FX 4
Retired Union Electrician
Don’t do this! The only correct way, according to the National Electrical Code, is to use a Neutral Switching Transfer switch, (3poles instead of 2).
https://www.generacpowerproducts.co...ac-HomeLink-Manual-Transfer-Switch/p/G0068541
Code allows for only one grounding source on a service To ensure that your breakers will trip during a short circuit to ground.
Lefty665
Cliff
Beaverdam, Va
2024 F150 XLT Powerboost Antimatter Blue, '98 Mustang GT, '64 Olds 442
retired IT
3 wires from PB to house panel. 2 hots and a neutral will prevent ground faults. An auto interlock to prevent back feed to the line will make you much more popular with your local linemen and power company. A sub panel (commonly bundled with interlocks) with circuits you want powered by PB and which will not have demand exceeding 7.2kw total, or 3.6kw per leg will make for a happier experience.
For the OP who was either unwilling or unable to search the forum for several extensive threads on using PB to power a house the answer is call an electrician and get out your checkbook.
Tks to a couple of you who have provided links to those threads. (y)
