new tires have a oily film on them. so you need to take it easy with them for a while until the film gets scrubbed off. also, check your tire pressures as well. could affect the grip and handling. also, do you know if you actually are locking up the rears or is it just a feeling?3 weeks, maybe a couple hundred miles. I didn’t realize tire break-in was still a thing but I’ll have to look into that.
Good to know... THX!FYI that is not recommended unless you have the 4A transfer case (Lariat and up). 4x4 is meant for LOOSE surfaces only (gravel, snow, dirt).
You are welcome! Check the users manual, it does a great job explaining when and when not to use 4x4. I'd hate to see driveline damage occur on your new truck!Good to know... THX!
I can hear them skidding which stops when I let up on the brakesnew tires have a oily film on them. so you need to take it easy with them for a while until the film gets scrubbed off. also, check your tire pressures as well. could affect the grip and handling. also, do you know if you actually are locking up the rears or is it just a feeling?
lol..You are welcome! Check the users manual, it does a great job explaining when and when not to use 4x4. I'd hate to see driveline damage occur on your new truck!
Cheers
Scrubbing off the mould release agent from tires shouldn’t take much more than 25 miles.3 weeks, maybe a couple hundred miles. I didn’t realize tire break-in was still a thing but I’ll have to look into that.
One of the reasons some roads in Texas, the Southwest and SoCal are so slippery in the rain is that they have been soaked by oil and other slippery adulterants without any opportunity for it to run off during dry weather. That first rain after a dry spell will make roads worse than ice!This could also be caused by slippery pavement. Example: Austin Texas. Holy cow the freeways are slippery there...
Californians seem to have issue with pavement that isn't 100% dry, so I'm inclined to believe it's slippery pavement and not the tires or (necessarily) the driver.
I was experiencing rear slip in rain with the stock tires. I now have the Toyo at3 275/60R20 P rated on screw fx4 XLT Powerboost and I have not experienced slipping in rain. I mean if you put the hammer down rear end will kick out but these trucks have so much torque they will spin the rear on dry pavement. Toyo was a big step up from the stock hankook's.Would’ve really liked to get 4a but my first two trucks were xl’s so this xlt 302a was a step up and the price really floored me! My biggest concern right now is the braking because I live in a hilly area and in the snow belt. I’m inside the return window right now but if I wait til the snow starts coming it may be too late. I had coopers, bfg’s and goodyear kevlars on my old trucks and didn’t have this issue. That’s why I’m not sure if it’s tire related or not. What are the chances that a tire can have poor wet traction but still have good snow traction?
I think the difference here is you have p rated tires where as mine are LT and probably a harder compound. I can no doubt spin my tires when it’s dry out if I punch it, but I’m a boring “slow” driver and I just shouldn’t be doing it with light throttle.I was experiencing rear slip in rain with the stock tires. I now have the Toyo at3 275/60R20 P rated on screw fx4 XLT Powerboost and I have not experienced slipping in rain. I mean if you put the hammer down rear end will kick out but these trucks have so much torque they will spin the rear on dry pavement. Toyo was a big step up from the stock hankook's.
Yesterday here we had a bad coating of black ice in the morning and lots of cars were not able to get up small hills, city busses taken off the roads and I had no problem getting to work.
