Rockman5159
I have a similiar situation on my 2021 FX4 rcsb. I have a sort of drone or rotational type light vibration that starts at 40 amd continues until around 60 mph. I just had it serviced and had it checked. They said all they heard was tire noise. I did remove blocks from underneath leaf springs. I 'm going to put pinion shims to correct the angle and see if that helps. I had a202 FX4 that i removed blocks and had no issue. If you come up wit a solution ,please let me know . ThanksI now have all new tires, new torque converter, new driveshaft and the latest TSB. The truck still vibrates the same. Ford knows it is an issue which is good, but they believe they can still fix it. I am beginning to think it is either a bad design or some bad transmission out there. I have been with our my truck 3 out of the 6 months I have owned it.
