SALEEN961
- Joined
- Jan 1, 2023
- Threads
- 12
- Messages
- 653
- Reaction score
- 876
- Location
- Radnor, PA
- Vehicles
- 2021 F150 XLT 302A
- Occupation
- Automotive Technician
I swapped out my ESOF transfer case for a Raptor TOD transfer case.
Your parts list looks plausible assuming you only want the standard TOD t-case, you're keeping your eIWES, you have no e-locker, and your build date falls in the ranges listed below. If you're build date falls outside of the ranges listed below, but you are using these parts to keep your eIWES, the list should still work but it won't be a configuration that Ford offered from the factory.
NL3Z-14B596-CB
10/12/2020 - 11/15/2021 4X4 2 Speed Transfer Case With Tod, Rear Axle Less Limited Slip Diff
ML3Z-7E453-P (TM377)
07/22/2021 - 11/15/2021 4X4 2 Speed Transfer Case With Tod, Rear Axle Less Limited Slip Diff with eIWEs
ML3Z-7A195-AK
From 10/12/2020 TOD Transfer Case; 2.7L. F-150; TOD Transfer Case; 3.5L; w/o 4HI-LOC; w/o Hybrid. F-150; TOD Transfer Case; 5.0L
NL3Z-14B596-CB
ML3Z-7A195-AK
