Update* causes lanekeeping by default
Dunthupl
Hunt
New Orleans
22 F150 Platinum
You used to be able to turn off manually and it would remember Off or ON. Now I'm getting prompts that 'bluecruise is available' and when I turn on cruise control, lane keeping is automatically applied every time...its a pain. What gives? Any permanent solution?
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
Weird…….mine doesn’t do that
WA_502A
KC
E. Washington
2022 Ford F-150 Lariat 502A
Mine started doing the same after the update. Super annoying. I haven't been able to find a solution but there has to be way.
Lawduck
Martin
Springfield, OR
2022 F-150 Lariat
I just got my 1.4 update to install yesterday, and while poking around in the vehicle settings, there's an option (as I recall, I'm not in front of it) to disable the automatic lane keeping function. I wouldn't swear to that, but I'm pretty sure I saw that option.
TPPJR
Thomas
2023 F150
I think you might be right I just checked and under adaptive cruise control lane centering was on. I’ll have to wait till my trip home to see if turning that off stops if I’m coming on automatic with cruise control or if it disabled it completely.
WA_502A
KC
E. Washington
Curious if that works for you. I tried that over the weekend and lane keeping continued to automatically engage.
There's a forscan setting for this, ford just made it enabled by default to surprise drivers with blue cruise to sell it because people weren't using it.
WA_502A
KC
E. Washington
Do you know which module and values need to be changed?
well it's controlled by the IMPA so I'd start there. it'd take us both equal amounts of time to locate.
Lawduck
Martin
Springfield, OR
2022 F-150 Lariat
I haven't actually used it yet. Might this weekend, so I can't say whether the setting sticks. (Although arguably if you save to a driver profile? Dunno, just spitballin' at the moment.) I'll definitely update when I get around to giving it a shot.
UGADawg96
JAX, FL
This happened to me back in the fall with an update to the truck. Anytime cruise is activated, lane centering is activated. It is very dangerous when towing. And I never want to use it on two lane roads. This doesn't happen in my 2025 Explorer ST. Can enable cruise and it doesn't turn on lane centering. If this is possible to disable and return to how it worked for three years on this truck with Forscan, then it would be the one thing to make me figure how how to finally download and use it.
Dunthupl
Dunthupl
Hunt
New Orleans
22 F150 Platinum
SOLVED : thank you. they buried it in the general settings now instead of toggled from the steering wheel. This resolved my issue.
