ARE THEY PRETTY STRONGIn the past I have used L track in a truck. It looks better to me.
https://www.uscargocontrol.com/coll...ygMxdE5k0B5XdMPcPZG7Y8FJTMAc0sEGdxySFBoFsB_Fk
This is the way to go. Been around this system for decades. It’s awesomeIn the past I have used L track in a truck. It looks better to me.
L-track was originally used in airplanes to hold seats down. So very strong. Just buy quality L-track, not Amazon Chinese pieces. Mac's Tie Downs Versa-tie is an example.ARE THEY PRETTY STRONG
Do you know if they can be installed in the bed floor?L-track was originally used in airplanes to hold seats down. So very strong. Just buy quality L-track, not Amazon Chinese pieces. Mac's Tie Downs Versa-tie is an example.
https://www.macscustomtiedowns.com/track/l-track-versatie/kits/c/214/
yep. lay it out, mark holes, drill, bolt it in. you could do blind nuts/rivnuts too. Also, maybe need to run a strip of flat bar under the bed to strengthen it? it's pretty thin material (the bed)Do you know if they can be installed in the bed floor?
Spring is almost here (good tinkering conditions), and this sounds and looks way better than the uni-strut. Thanksyep. lay it out, mark holes, drill, bolt it in. you could do blind nuts/rivnuts too. Also, maybe need to run a strip of flat bar under the bed to strengthen it? it's pretty thin material (the bed)
Very strong / robust. I installed L-Track along the sidewalls of my previously owned Honda Ridgeline, the system of both track and drop-in tie-down fittings was hell-for-stout.ARE THEY PRETTY STRONG
Yep, that's where the L-Track's low-profile really shines.Do you know if they can be installed in the bed floor?
good advice. I used heat shrink tubing on bolts where they pass through aluminum from truck tool box to the bed.Very strong / robust. I installed L-Track along the sidewalls of my previously owned Honda Ridgeline, the system of both track and drop-in tie-down fittings was hell-for-stout.
The ultimate pull-out strength is going to be a function of the fastener system you use to mount the track to the bed and the spacing / number of those fasteners.
Being aluminum there's not any corrosion / compatibility issue with the L-Track itself on our beds, but if you use SS fasteners (recommended, IMO) you should isolate those from contact with the truck's AL components. See the attached Ford Guidance for ideas about how to accomplish that.
Bonus on top of all the functional benefits - it's a great looking system!![]()
THAT is great information- I had no idea- gonna print it out and stick it in the truck as a reminder- ThanksVery strong / robust. I installed L-Track along the sidewalls of my previously owned Honda Ridgeline, the system of both track and drop-in tie-down fittings was hell-for-stout.
That should workI used heat shrink tubing on bolts where they pass through aluminum from truck tool box to the bed.
