Turn Signal Cameras???
Spiffy
Usa
2022 platinum powerboost
so what were seeing is no 21's or 22's can get this to work? but it works on 23's?
the 23's have different IPMA if i recall?
I recall that Jesse-Infotainment said all ipma were the same?
"APims are the same. Software is changing adding newer items"
Does anyone know the last Ota update that targeted/included the ipma?
crazywayne311
Wayne
Hampton Roads, VA
CTMO
Guess I’ll continue to follow this. I haven’t done any changes but if it didn’t work on one 22 already I’m sure it won’t on mine. Mines an early 22 that has no deletions but may not have the right software bc it’s an earlier build. May have to wait for an OTA
C. Mays
22 F-150 Lariat; 25 Subaru Forester Sport
Project Management
Mine was built in December of 22. I know I did an update to the IPMA, but that was awhile back. Updated via FDRS this weekend and only had an ABS, HCM & APIM.
crazywayne311
Wayne
Hampton Roads, VA
CTMO
i believe mine is a 1/22 build but i'll have to check the sticker again to make sure
dhageremtp
D
North Dakota
2022 F150 Lariat
Healthcare
Anyone get any new intel on what is needed to make this work?
Iceman2022
Jake
2022 F150
Controls Engineer
Does the IPMA also handle lane centering and adaptive cruise control? I have been using as built files from my Dad’s ‘23 501A Lariat in my ‘22 302A. I just put the whole APMI file in mine and I finally have driver profiles now. I’m concerned about doing the same with IPMA because his truck doesn’t have copilot 2.0.
Spiffy
Usa
That's only when in reverse? My son's Honda civic displays the camera with turn signal. If I had to pick just one feature for my truck that would be it.
  • Like
Reactions: sbi
Stefanolimotta
stefano
21 f150
Construction
I mean really you just need the VIN of a SD that you know has the trailer turn signal function that works, download the AB files for it and compare. You don’t need a whole bunch of trucks to have AI compare for you. I’m fact, people have already posted what values they think need to be changed:
  • trailer turn signal view
    • IPMA
      • 706-01-02: 3xxx xxxx xx
    • APIM
      • 7D0-02-03: xxxx x8xx xx (or C)
      • reset APIM under wrench icon
But I have yet to see where someone has them hooked up a trailer and tested. I will at some point, but it will be a few months before my trailer is out and available.
Would you happen to know what the lastest apim is. Also would ford be able to update that for me? I have a 2022 xlt
B-real
Utah
2023 F150 Tremor 3.5
Not sure on the latest APIM, but trailer turn cameras only work on 23 models. Could be because of the APIM, could be due to something else, haven’t heard the reason tracked down
rugedraw
Javier
Miami
Auto Sales
Ok, so after re-reading this thread, maybe one of you guys can help me understand something. Does this work on 2021's or not? I flashed my IPMA with the software from a 2023 HD last night (with the help of someone who knows what he's doing because I sure as hell don't) and made the FORscan changes mentioned by @B-real on the first page of this thread:
    • IPMA
    • APIM
I am not getting the toggle on the driver assistance screen to turn the feature on. I will be trailering my boat down to the keys tonight and was hoping to be able to test this out, but not sure what we did wrong.
rugedraw
Javier
Miami
Auto Sales
Never mind.......FORscan changes to the APIM and IPMA were NOT done. I'll make the changes tonight before I hook up the boat.
B-real
Utah
I was told this only works on 23s, but never heard why. I just know some with 21s and 22s have tried and couldn’t get it to work
rugedraw
Javier
Miami
Auto Sales
I was told this only works on 23s, but never heard why. I just know some with 22s and 22s have tried and couldn’t get it to work
I'll report back here if it works or not.
rugedraw
Javier
Miami
Auto Sales
Another thought going through my mind is if the lighting on my trailer will have enough of a draw to trigger the system to work since all the lighting is LED.
