Track or acceleration times for a crew cab?
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
Has anyone taken theirs to the track or have verified Dragy results for the 1/4 mile? Interested in what Screws are doing. What is the expected time? ET/MPH? What did the 13th gens do stock?
PW2150
Phillip
2021 f150
Construction Superintendent
My Screw 4x4 did 13.73 @ 99 mph last winter. It is not the lightest truck (loaded 302a with sunroof).
Ford F-150 Track or acceleration times for a crew cab? CADB8147-707D-40DE-B947-02A371DB48FB
diambo4life
diambo4life
OKC
Assassin
Damn....that's pretty good. I was not expecting it to dip into the 13s....I will definitely have to wait until November when we have good DA and run it on E85.
diambo4life
diambo4life
OKC
Assassin
Sport mode? Turned off any traction control or anything?
PW2150
Phillip
2021 f150
Yeah, sport mode TC off , 4h and it seems to do better if I hold the brake, floor it , and launch as the rpm’s climb close to the stall. Maybe a fluke but this method was consistently quicker than holding the brake and gas a few seconds and launching it.
PW
Mike2019SCrew
Michael
Humboldt, TN
2022 4WD 5.0, 2019 2WD 3.5 SCrew FBO previous
Similar Dragy results here, 3.31 gears 5.0 4hi launch, best was 5.29 0-60, and a 13.64 1/4, on 93.
EDIT: That was sport mode, TC off, going from auto hold and just flooring it.
diambo4life
diambo4life
OKC
Assassin
Awesome. What was the mph and 60?
Mike2019SCrew
Michael
Humboldt, TN
Ford F-150 Track or acceleration times for a crew cab? Screenshot_20220922-075056_dragy
Hit speed limiter a few tenths before finishing the 1/4, possibly even a full second.
diambo4life
diambo4life
OKC
Assassin
That's incredible to me that these bricks are trapping 100mph N/A lol. Just. Wow. Mine may be slower due to having heavier wheel/tire combo so we will see when I take it there in November.
diambo4life
diambo4life
OKC
Assassin
Mine is noticeably slower to 60mph than you boys but the mph is right there with you. Also interestingly, mine has a 95mph speed limiter. It literally stops accelerating a little bit before I hit the 1/4. My best is 14.15@95mph.
I have a catback....18" wheel/tire combo and subs under the seat. maybe an extra 100lbs would be my guess.
dolsen
KY
2022 Rapid Red 701A
As I am sure you know, the catback is likely to shave some weight (stock exhaust is HEAVY and the corsa stuff seems to be on the lighter end for aftermarket exhaust), the subs probably add a bit of weight, but I would consider that trivial vs the added unsprung mass of the heavier wheels/tires.
I am a little baffled by your 95 mph speed limit though, mine is 102 with T rated tires. Did yours come from the factory with S rated tires? It seems the speed limiters are set ~10mph below the tire ratings.
diambo4life
diambo4life
OKC
Assassin
I will have to check what tires it had stock. I can't remember....I made like 3 hits and it bricked all 3 times at 95mph.
diambo4life
diambo4life
OKC
Assassin
Hankook Dynapro AT2
Speed Rating: S (112 mph) Load Index: 126. Load Range: E.
That was the stock tire on my truck.
dolsen
KY
2022 Rapid Red 701A
Hankook Dynapro AT2
You had 10-ply tires from the factory? that seems odd, I didn't think these came with anything other than passenger tires. Maybe I'm confused lol.
Yea I was a bit off on the speed ratings, I haven't looked at those in a long time, mine came with T rated tires which have a speed rating of 118. Either way there is quite a large margin in the top speed limit vs the tire speed rating.
