mrowenz
Josh
North Carolina
2024 f150 stx 2.7 2wd
Maintenance
Figured I would post here for anyone with a 2wd wanting to see tow hooks installed. They can be easily installed without removing the bumper. You just need to remove the active air dam valance itself. *Not the actuators. Just the plastic part(6 small screws) in order to tighten the rear bolt of the tow hook. You will need to modify your front valance in order for them to slide in. I opted for this route to avoid the need of purchasing a 4wd version. But honestly still looks great. A jig saw makes quick work of it. Just mimicked the lines of what a 4wd would be. Hope this helps anyone in similar situation to have a visual.
Ford F-150 Tow hooks installed on 2024 2WD F150 IMG_0596
Ford F-150 Tow hooks installed on 2024 2WD F150 IMG_0598
Ford F-150 Tow hooks installed on 2024 2WD F150 IMG_0599
Ford F-150 Tow hooks installed on 2024 2WD F150 IMG_0600
Ford F-150 Tow hooks installed on 2024 2WD F150 IMG_0597
JumboJVT
Kris
Vermont
'25 F150 302A 157" 3.5EB
Project Manager
Long experience tells me that with 2WD, you'll have much less need for tow hooks than those with 4WD. Old friend of mine always said "go as far as you can in 2WD then put it in 4WD, turnaround and go home". Folks with 4WD seldom heed this advice, while those with 2WD know better. Install well done though.
retrodreams
2023 XLT Sport 302A 5.0L V8 Coyote w/ Tremor Tails
Nice, where'd you get the black emblem? I'm debating the black OEM emblem, or one of these even darker gray/black custom emblems. Can't decide....
mrowenz
mrowenz
Josh
North Carolina
Maintenance
