scott011422
Is it possible to start and drive these push button trucks without hitting the button? Obviously there is remote start, But you cant drive the truck on remote start. There are alot of vehicles getting stolen thru the CAN system. Can the truck be started and driven away thru the CAN?
Adding an easy kill switch is difficult with all the modules on board. Don't want to be setting check engine lights all the time.
So I've been looking to see where I can make it impossible to easily steal a powerboost. On my 05' I had a switch on the power wire to the fuel pump module. Worked great. These new trucks thats on the CAN so it would set a check engine light. Granted, It would be easy enough to cut the fuel line and add an electric valve. However, Being a power boost, that wouldn't necessarily stop them from taking the truck depending on how much power was in the HVB.
It wouldn't be too hard to disable either the shift unlock button, or even the shift unlock solenoid. I wouldn't think a thief would just pull on the shifter like his life depended on it, but what do I know, Not a thief.
My other thought would be to add a switch to the push to start button. Even with remote starting, you still need to press the button to "Authorize" the truck to operate normally.
