RcFlyer330
That +1 keeps getting added because it is the country code. #1 is for the usa #20 is for egypt every country has a different code. All it for is to tell the operator what country you are trying to dial to. technically if you are dialing someone in the same country youself, you dont need the country code. But sometimes if you dont put in the country code the number won't go through so it won't cause a problem having it there.YES SIR i agree
i think thats why it displays it as an INVALID number , not every time, but often.
i removed the 1 before area code then the number
verizon adds it back in a few days later. yet my number , which is exactly the same except the last digit, both numbers were activated the same date many moons ago etc
its perplexing
if i use the phones key pad, it goes right through as normal
but if use sync screen it acts like it cant find it, or tries to call then hangs up
or places call then hangs up right as it should ring, withe invalid number. or it appears to hang up or not go through then all the sudden i hear her voice and then call connects.
