Engine masters pretty much provedMy assumption is that under high loads and long durations with a short exhaust (side exit pre-axle) or cut-outs, don't create enough exhaust system backpressure, and thus could result in; too high of temperatures for the exhaust valves, catalytic converters, or maybe just cause the system to run too lean...either way, they have you limited for 3-years, 36,000 miles. after that warranty is done, so let'er rip!
Or these are arbitrary modification's the lawyers figure only people who race their trucks and/or abuse them would do, so they have to protect themselves from warranty costs.
Now that you mention it, I remember 1997, all the f-150's had side exhaust back in those days until Ford has mass Warranty claims for rims, 1998 was back to exhaust out the back.Engine masters pretty much proved
Boosted engines do not need back pressure downstream of turbo to run efficiently. Or supercharged engines
Less is best
Side cut outs issue seems dumb
I seem to remember a few f150 jelly bean looking trucks with pipes exit right before rear tire....
You're right about that-in fact, back pressure downstream of the turbo is VERY effective at killing power. Richard Holdener proved that by swapping post-turbo exhaust systems back and forth and demonstrating how much power disappears when you introduce more post-turbine back pressure. The turbo spins because of a pressure differential across the turbine housing. Any pressure after the turbine housing reduces the pressure differential.Engine masters pretty much proved
Thank you for the clarification!That is not correct. ALL wheel drive vehicles are not covered but FOUR WHEEL DRIVE vehicles are. There is a fine technical distinction between 4wd and all wheel drive, and Whipple considers that distinction. I know-I called them myself and asked them exactly that question for the same reason you brought it up. As long as the truck does not have an awd system, which I take to mean something that can automatically engage the front axle without being told to by the driver, it will cover the truck. Now, you are correct that the transfer case and axles are not covered.
