Rough idle from the ICE when cold
Hans Moleman
SF Bay
Does anyone truck have rough idle with the gas engine when cold?
Mine engine seems to have a rough idle when the it is cold. At 1000 rpm there is a lot of vibration/resonance/rumbling which causes the dash and skid plate or heat shields to rattle.
Once the engine is warm it’s pretty smooth, if hasn’t switched over to electric mode..
No service engine light and Forscan doesn’t show any DTC’s.
Is this just the nature of this engine? I wonder if the regular 3.5 ecoboost is also like this.
22Platinum
2021 KR 3.5
software engineer
I have rough idle (500rpm) on occasion though mostly warm, and I have shuddering/surging around 1000RPM in high gears at low load (40mph, 9th-ish gear).
I think I read that 3.5s have had shaky idles, something like low oil pressure; was true on earlier models.
dbtgt
Oklahoma
2024 F150 501A 3.5 EcoBoost
Mine engine seems to have a rough idle when the it is cold. At 1000 rpm there is a lot of vibration/resonance which causes the dash and skid plate or heat shields to rattle.
Intermittent rough idle is a common characteristic of the 3.5L Ecoboost engine. Sounds like it carries over to the 3.5L Powerboost engine.
Hans Moleman
Hans Moleman
SF Bay
that’s good to know. I hate to have the dealer to start replacing parts and potentially cause other problems
dbtgt
Oklahoma
I noticed it on the first drive of my 2021 EB when it had 21 miles on it.
Still does it at 49,500...
Gord0
Gordon
2021 Lariat 502a
The 3.5 Ecoboost is known to occasionally have a rough idle. My 2013 had it from when I got it till over 200k miles. My 21 has it as well. I replace spark plugs a LOT earlier than most (30-50k) and gap to .028". That helps a lot.
Samson16
Orlando, FL.
Aviation systems
I also experience an occasional "rougher than normal" idle. I think the module that controls and decides the air/fuel ratio, ignition timing, and valves is confused a bit somehow when that occurs.
Captain Obvious reporting for duty
Aim64
New York
2018 F150 Limited Ordered 2021 F150 Platinum
Scrap Metal Industry
Same here with my 21 Platty 16,000 miles on it
KirkBay
Kirk
Prescott AZ
2021 FX4 PowerBoost, 64 El Camino, 65 Mustang Conv
Software Engineer
As does my 21 PB with 105K on it. Some days more than others.
Hans Moleman
Hans Moleman
SF Bay
