jdmsti101
- First Name
- Ray
- Joined
- Sep 19, 2022
- Threads
- 0
- Messages
- 3
- Reaction score
- 0
- Location
- F150Gen1410!
- Vehicles
- 2022 F150 PowerBoost
Question…do you just remove it RAS by unbolting the bolt on the bracket, do you need to dial the spring back to no tension before removal?I did finally get around to removing and cleaning the contact points on my RAS, and all the noise is now gone. I've had them off road a few times and so far the dirt hasn't made the noise come back.
When I re-installed mine I went bit tighter, since I have a load in the bad most of the time now. I don't know the exact setting, but the white disc fell right through the spring spaces and now resides inside one of the springs permanently. I think it was pretty close to a mid point between the two discs, but instead of using a disk to make them match I grabbed an old spark plug gap tool to avoid feeding them anymore plastic chips...![]()
