Request VIN Lookup Thread
Efalcon80z
2021 Ford F-150 King Ranch Power Boost
Thanks in advance.
blankkey
Metro Detroit, MI
21 F150 Lariat PB
I would really appreciate if someone could check this VIN please.
I spoke with Ford Software Update support and they gave me a case number stating there appears to be an issue with communication between the BCM and APIM. Connected functions work, but no software updates so no BlueCruise or recent Sync 4 updates like Full-Screen. Sync 4 about says it's currently on 22177_PRODUCT Rev. 473.
Thanks
Thanks
Welcome to the forum. This truck has the APIM replaced in May and it seems to have been programmed correctly. The reason those you don't have bluecruise or full-screen capability is because the software on the truck is very out of date....it has nothing to do with that code. Connectivity does seem to be working, but the older updated this truck needs are rarely pushed out by the servers. As far behind as you are, I would recommend you invest in the tools needed to update it yourself and get everything working.
TexasTea
Here
2021 F150 Tremor 402a
Request vin
Removed
DESPERATELY waiting for sync update... This truck has drained its battery ever since I got it...
Dealer on the phone says my truck has updates but needs to come in for them. Any truth?
Request vin
I don't even need to run the VIN to check. Sync 23159 is two versions behind the latest one, so for sure you have updates pending. The problem is Ford's OTA process is slow, unreliable and unpredictable. If you're able to set up FordPass, then your connectivity is working and your truck is fine.
TexasTea
Here
Yeah I mean a couple weeks ago I got a Bluecruise update....... I don't have Bluecruise. -_-
2022 F-150 Lariat SuperCrew 3.5 Ecoboost
Greetings, all.
@rugedraw I have a new to me 2022 Lariat 3.5 EB. I was wondering if you could check my VIN, and see what, if any, OTA updates I have\need.
Thanks!!
Flyinglemi
Eric
Central Wisconsin
2021 F150 XLT Supercrew 6.5ft bed
Law Enforcement
I, for one, think this is a GREAT idea.
When you ask for a VIN check, please specify if you are looking for OTA updates, or if you need to see what specific modules have updates pending on FDRS.
Can you run my VIN? I haven't had an update on my 21 for months now and I am getting the frequent phantom updates. They've replaced the APIM, 2 batteries, and reprogrammed the "brain" module due to 2 codes being seen.
I'll look into that tomorrow, but you'll still get the ipma update even if you don't have BC.
Edit: Surprised you got that OTA considering how far behind you are with the other modules, tbh.
@Nightranger4x4 @Flyinglemi
I will gladly check the your trucks out, but please remove the VIN from the thread and message it to me.
I didn't think I put my VIN in here...I just DM'd it to you.
Appreciate the response!
blankkey
Metro Detroit, MI
21 F150 Lariat PB
I am able to use FordPass and connected maps so that makes sense.
@ruggedraw Thanks a lot for your help. I’ll do that.
Your truck is on Sync 23291 which is one version behind the latest one. Pending updates are below. Once you receive the GWM update you see there, it will release an update for your APIM that will bring you up to the latest version. Seems like this truck has been updated frequently with FDRS by the dealer. The more updates they do, the less you will receive. I see nothing wrong with your truck.
Your truck is on the latest Sync version and pending updates are below. You are not behind at all.
jets2022
chris
wake forest
2022 powerboost
I have a 22 powerboost. Wondering if i have any updates for my Truck
Thank you
Thank you
I'll gladly check, but please remove the VIN from your post.
Truck is on Sync 22294 which is pretty old at this point. Modules with pending updates are below. Connectivity seems to be working fine.....hard to say why this truck has fallen so far behind, but it is a bit behind.
